Silent Thunder Removal 89’ 242 LS >
Silent Thunder Removal 89? 242 LS
Old 06-07-2022 | 12:12 PM
  #81
Originally Posted by Johan Smas
Wow this looks very good!
Why did you leave the u-bolts? May be obvious to others but I'm ultrabeginnerboater
I use mine to strap the boat to the trailer
j272 is offline
Old 06-07-2022 | 08:31 PM
  #82
Exactly, I strap there as well down to the trailer. I did remove the upper ones that helped hold the ST platform on, I didn’t want those in my back when sitting on the platform and I didn’t have any other use for them.
Noles1 is offline
Old 06-09-2022 | 10:45 AM
  #83
Looks awesome man! Better than factory!! What straps do you use for the trailer? I'm having a hard time finding ones that go that short since it's only like 16"
CharlieWhiskey85 is offline
Old 06-09-2022 | 11:02 AM
  #84
I usea wide long strap that goes through the trailer frame and out on each end to the loops on the boat.
j272 is offline
Old 06-09-2022 | 11:05 AM
  #85
97FASTech's Avatar
Veteran: Army
Check on etrailer.com, they some that are 2" X 2 ft.
97FASTech is offline
Old 06-09-2022 | 09:05 PM
  #86
The straps are from quite awhile ago (although still like brand new) that my dad used for his boat. They have Pier 33 embroidered on them. They are very easy to adjust, tighten/release, and work great for my short length application. I can always send you pics of the style if you want to see them.
Noles1 is offline
Old 06-23-2022 | 03:35 AM
  #87
Default Hinge for engine hatch
Hi there! We have a 1987 242 LS. Long story short, we are getting our sundeck/engine hatch back today but are unsure how to attach it to the boat. Does yours use a piano hinge or more traditional automobile type hinges? Thanks!
Stickboy is offline
Old 06-23-2022 | 05:01 PM
  #88
TomZ's Avatar
It uses neither.
There is a bracket on the left and right at the rear of the hatch bolted to the boat. The matching bracket mounts to the bottom of the hatch and is through-bolted using the upholstery wood to help support the hatch. The brackets are mated to each other via a 1-inch long 1/4-inch bolt and nylock nut (I might get out to mine this evening... I can get a pic).
If you don't have the brackets, then you probably haven't drilled the wood and added the through bolts. The bad news is that you'll need to open up the upholstery to do this. The through-bolts also need to be bolted to the wood before going through the fiberglass shell (there is room to run the bolts through and secure with large washers and nylock nuts). Not a hard job to do but will require some disassembly.
TomZ is offline
Old 06-23-2022 | 08:43 PM
  #89
I found a pic I had of engine compartment and zoomed in for you to give you an idea of hinge. I can get better ones this weekend if you need.
Noles1 is offline
Old 06-24-2022 | 09:23 AM
  #90
CBlakeNS's Avatar
Well done, love the color.
CBlakeNS is offline
