New Formula Owner
[i]
We were able to get the boat up to 54mph yesterday as the lake wasn't quite as rough. Still trying to determine why we aren't running closer to 60mph.
Kenny [/B]
Kenny [/B]
Thanks to Formulafastech and Cuda for the responses. I am sure now after your answer Formulafastech that the spray is quite normal, although I wonder why it seems to only be coming out of driver's side exhaust and not both sides. Cuda--ironically, the speed has increased since the installation of the batteries, but it probably relates to burning off lbs of gasoline. I just keep thinking there is something fundamentally wrong with the setup somewhere since I am using a 19 inch pitch prop and WOT is 4800 whereas others here are using up to 29 (I think). I am wondering if there is some way to verify the gear ratio since Formulafastech first raised that issue. Here is theMercruiser prop selector I used to arrive at the REV 4 prop I just installed.
http://www.mercurymarine.com/prop_selector
Kenny
Kenny
