As I recall my conversation with TAG, they said the 336 is a 311 with a molded platform. The hullsides (freeboard) are a little higher and the decking is different, a bit higher. This accounted for the weight difference. Other than that, it's the same boat.
ThirdBird how does the yukon haul that thing? also which motor, 6.0 or 8.1? whats your everyday mileage?
Originally Posted by 88242LS
(Post 3032000)
My Yukon hs the 8.1 (496), 373 gears and it does very well. Now, it is at it's rated max for sure but it does tow very well, no lack of power. Towing I get 8-10 mpg depending on hills. Everyday average is about 11 mpg. Interstate cruising (no trailer) at about 68 mph, I get 15 to 15.5 mpg. I'm very happy with it, it's an '04 and only has 40k on it. I don't use it as a daily driver. |
Originally Posted by ThirdBird
(Post 3031886)
Well, that's very interesting. I also called Formula (TAG) when I bought my used Eagle trailer. The trailer was made for a 336. I called, told them I wanted to put my 311 on an Eagle made for a 336. They said it's the exact same hull (as far as the running surface) and that it would sit right on it perfectly. They were right, sits perfect, trails perfect. Here's a picture:
I dont think there is a better trailer made ....I wish I could have kept the Eagle trailer that came with my 311...pulled smooth as silk ........m |
Wtfc!
Originally Posted by mkole
(Post 3032906)
Wtfc!
Um, what?! |
Originally Posted by offthefront
(Post 3032680)
I like the looks of the 336 but the dash sucks! easy fix though ......m
I love my performance trailer, everything welded including jack stand, which means less spots for corrosion to start
http://i495.photobucket.com/albums/r...s/HPIM4169.jpg |
Who cares, go talk on the right thread.
| All times are GMT -5. The time now is 02:04 AM. |
