New Merc Maximus 5-blades >
Old 05-09-2004 | 08:53 AM
Donzilla's Avatar
I would like to hear more about the 5 blades on a 353 with 500's no boxes. I put a set of 29 hydro 4 blades on yesterday had to trim it out to 5200 but hit 83 gps with more bow lift than b-1's
Donzilla is offline
Old 05-09-2004 | 03:08 PM
I think what you were really experiencing was more "whole boat" lift or keel lift as hydros are a stern lifter. Their semi surfacing design want to climb to the surface...thus giving more stern lift, and with enough power per lb. and LOA, more whole boat lift. The effect was most likely magnified by higher trim angles you were running over B1's.
Rippem is offline
Old 05-09-2004 | 05:10 PM
I need some serious help in this field, I am running labbed 24 B1's and am hitting the rev limiters at 71.8. I have no idea where to start with props. I just had boxes installed, and they are set on the middle setting. I would love any recomendations!! I am going to hold off on going to shorties for awhile (wallet is sore)
thanks
Corey
lonestar382 is offline
Old 05-10-2004 | 07:50 AM
THE GOOD STUFF's Avatar
[QUOTE]Originally posted by Magicfloat
Rex,your boat is running strong. What props are you running now and what Herings are on order? [ Robert, lab 33 now , Have ordered hering 6 blade 30 , Im stuck under the 90 mark, 86.2,87.8 88.2, 89, Ihave not seen 90 on the garmin gps or gaffrig gps speedo./Major slip factor with these props . Iwould like to also try some merc 5 blade. RexQUOTE]
THE GOOD STUFF is offline
Old 12-26-2004 | 05:17 PM
afton
Default Re: New Merc Maximus 5-blades
i have the same boat and setup but have 30 4 blades and only hit 78 and only seing 4800 rpms have any suggestions
Old 12-28-2004 | 08:21 PM
WAGS382's Avatar
Does anyone know what maximus formula is using on the 05 382 with the 525's or any other engine comb? I am interested in 5 blade props for my 382, should be approx 600 usable hp this spring. Jeff
WAGS382 is offline
Old 12-28-2004 | 09:27 PM
offthefront's Avatar
I bet those are more than 49.95 !!
offthefront is offline
Old 01-18-2005 | 12:14 PM
Goofy1103's Avatar
525 EFI and 525 EFI ITS 5 Blade 26 lab finished Maximus
Goofy1103 is offline
Old 01-18-2005 | 08:22 PM
WAGS382's Avatar
Goofy1103
WAGS382 is offline
Old 01-23-2005 | 01:56 PM
Jeff what are you doing to come out with 600 usable hp ? Im curious . I have followed your threads . You definately do your homework .Im almost there. I pushing 575 and 630 lb f torque . I think the 28 hydro 4 blade or 29 will the prop of choice. Waitin a warm day. Would love to see 85 mph. The torque litteraly idles me up on plane.
boatman747 is offline
