Finally started the exhaust swap out >
Old 07-30-2004 | 07:51 AM
Hi-Tech Marine's Avatar
Default Re: Finally started the exhaust swap out
Give it to a kid for about 15 minutes. You willl then have the full instruction live on use and features. I gave mine to my 13 yr old. Half hour later he wa showing me ting I didnt knnow it would do
Hi-Tech Marine is offline
Old 07-30-2004 | 11:55 AM
Formula Outlaw's Avatar
No kidding............
Formula Outlaw is offline
Old 08-10-2004 | 07:12 PM
QUICKDECISION
Outlaw,
I just pulled my exhaust off... They were Osco's and they are "HEAVY" .
In a vein to try to be helpful, I found that if I pulled the Alternator, and all of that paraphenelia, it made access much easier. I do that just to change plugs from now on.
For the exhaust... I strapped a 2 by 4 board ,about 5 feet long, from the lip of inner sun deck over to the opposite engine exhaust riser. I pulled 2 bolts about a quarter of the way from each end of the exhaust, and replaced them with longer ones... ( about 4 inches ) to kinda hold it after removing all of the original remaining bolts.
I tied rope around the exhaust riser to the 2 X 4 so when I broke the exhaust free from the gasket, it was supported by the 2 X 4 . I then pulled the remaining 2 bolts out and used the 2 X 4 to aid in handling the heavy exhaust. I hope this may be helpful. Doug ..... QD
Old 08-10-2004 | 07:30 PM
offthefront's Avatar
Russ .....these Tarps off ebay are 12x20 and twice as thick as the cheaper ones ...I also got a cpl of others off ebay I am using as temp roof on the boathouse ...you got 2 trees you could string a line on to drape a tarp over ?
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=5914527519
offthefront is offline
Old 08-10-2004 | 08:41 PM
Doug, thanks for those tips. I'd already decided I was going get as much out of the way as possible, and replace fan belts while I'm at it. I mean why stop now???????
Mike, what I did was staple a tarp to a 1x2 strapping and rolled it up. What I do is screw the strapping (after unrolloing the tarp obviously) to the facia board above the garage, (Outlaw is backed up to within two feet of the garage door), then tie it off to a palm tree and a power pole in the side yard that feeds our underground service. Works like a champ.....
This past Saturday I screwed off and took that ride on the Cig Tiger. Sunday I was too damn sore to even think about contorting around in that bilge. Now we've got two storms brewing. Keeping our fingers crossed they don't get too close. Russ
Old 08-11-2004 | 07:51 PM
cuda's Avatar
Come on slacker! I spent all day Sunday working on my 20 SC.
Attached Thumbnails Finally started the exhaust swap out-paint-two-017.jpg   Finally started the exhaust swap out-paint-two-024.jpg   Finally started the exhaust swap out-paint-two-027.jpg
cuda is offline
Old 08-11-2004 | 07:52 PM
cuda's Avatar
I'll grant you the fact I now have a garage to work in makes it a helluva lot more palatable.
cuda is offline
Old 08-11-2004 | 08:08 PM
how big is the Garage ?
Old 08-11-2004 | 08:24 PM
FORMULA 357 SR-1's Avatar
Cuda , What Were You Doing Under There ? Sanding Off The Remnants Of Barnacle Paint From The Bottom Of That Unit ?
FORMULA 357 SR-1 is offline
Old 08-11-2004 | 08:40 PM
cuda's Avatar
32x40, ten foot doors.
cuda is offline
