Help me decide.. Blower hatch or scoops
Originally Posted by Audiofn
Red Dog if you can get me some pictures that would be great.
Jon
Jon
If you post or PM your address, I will take some 35mm photos and mail them to you as soon as I can.
For the rest of you, I will try to get something posted in the near future.
Chris
Originally Posted by RedDog382
I'm going to see if I can get some of the "NO STEP" stickers they put on aircraft wings for my scoops.
Originally Posted by masi242
Jon, I like the look of both options if your not on the boat that much go with scoops, but lets remember may is just around the corner so lets get moving. Remember we need pics of all progress.
good luck
good luck
Jon
Put your best foot forward!
On my 357 with B&M 174s the hatch had to be raised only slightly and only in the back. it is tight but it clears. If you look at the back of the pic under the hatch you can see a very simple way of raising it with a piece of aluminum. Mine also has small wood blocks to raise it a bit further. it was like this when I got the boat so I haven't chenged it. It works fine. But, if I were to do it over I'd get a bigger piece of aluminum and not use the wood.
B-Ford: There are two concerns that I can think of. One is the clearence of everything. The other is actually getting all the air in there that you need to create maximum hp
Here are the pics of the hatch scoops from the back view... It's the only pic I currently have of them. Can't see them in the side pics I have available.
