Formula Dash Panels
#121
Those are PEM studs that are pressed into the panel. I would have used the type that presses from the opposite side of the panel......
The only thing for you to do is drill through and install a similar sized phillips flat head (like what holds the hinge brackets) or.....new panel! Next time.....try unlatching before you try to open the panel.
#123
I am working on redoing my dash panel on a '97 382. I was looking through some old threads on the subject and saw that you had some extra blanks made. Do you still have any left?
#124
I have the drawings for the stepped and flat main instrument panel for a 382. If you want them email [email protected]
#125
I ran across this site not long ago - could be an option if you really want to go custom & trick. Lot's of carbon fiber material and color choices. http://compositeenvisions.com/
#126
#130
