Performance Question on a 35 >
Old 03-29-2007 | 05:12 PM
jryan26's Avatar
I see your boats on boattrader.com. Looks good!
How is it running? Did you get the bugs worked out?
http://adcache.boattraderonline.com/6/4/2/84845142.htm
jryan26 is offline
Old 03-30-2007 | 08:35 AM
ALL IN's Avatar
can someone tell if there is harm done with over trimming i sometimes bring them up a little extra for the rooster tail when the kids ars tubeing or when i do a drive by.i always thought that as long as you still see it on the indicator you are good.?????????????
ALL IN is offline
Old 03-30-2007 | 01:41 PM
Shouldn't hurt anything as long as you have water pressure. Not the most efficient way to run though.
jmeng is offline
Old 03-30-2007 | 02:31 PM
Von Bongo's Avatar
The more you trim the more stress you put on the u jounts.
Von Bongo is offline
Old 03-31-2007 | 07:37 PM
35 fountain's Avatar
That is a bad idea - you are totally stressing out the u joints and god forbid they bind, you will blow up the tansom assembly when they come apart and your direction will change from forward to down. Stop doing that.
35 fountain is offline
Old 04-01-2007 | 01:55 AM
HiPerf2000's Avatar
YEP !!!!!!!!!
HiPerf2000 is offline
Formula25
08-17-2007 01:35 PM
Maritime_Eng
02-25-2007 08:51 PM
gripit
4
12-12-2006 02:07 PM
mardonzi
1
04-03-2006 05:37 PM
johnkot
6
12-31-2004 12:08 AM
