Help!!!!! Boat Wont Plane!!!!!!!!! >
Old 06-20-2006 | 10:43 AM
candyman35's Avatar
Default Re: Help!!!!! Boat Wont Plane!!!!!!!!!
Originally Posted by carney
Is it possible that you have one drive cable in forward and one in reverse, One cable goes on top and one on the bottom of the assembly ?????????. and or check fuel pressure.
Was thinking the same thing.
The Throttle cables go on the furthest back hole on my '97. I would do as Birdog said. He knows his Fountains!
Dan
candyman35 is offline
Old 06-20-2006 | 12:13 PM
One foreward, one reverse, boat would rotate as when docking.
RaggedEdge is offline
Old 06-22-2006 | 06:55 AM
carney's Avatar
But if both drives are in forward the reverse rotaion prop will be turning back wards. , Am I thinking right .
carney is offline
Old 06-22-2006 | 08:35 AM
sleeper_dave's Avatar
I've noticed that my boat planes better with the drive at 3 or 4 than it does with the drive all the way in. The prop starts to ventilate a little, the revs come up, the power comes on, and bam, it's on plane. If i trim it all the way in it just lugs along at 2500 rpm until it drags itself on plane.
sleeper_dave is offline
Old 06-22-2006 | 10:46 AM
FOUNTAINATLAST's Avatar
Interesting what size is your boat, May be something new to try. You still using your tabs???
FOUNTAINATLAST is offline
Old 06-23-2006 | 05:36 AM
blownincome's Avatar
Do you have MPI/or 496 Motors If so they may be in Protection/limp mode?? You would need a rinda tool to Diag..if so clear the fault code and your Off
My .02
blownincome is offline
Old 06-23-2006 | 02:39 PM
itilldo's Avatar
I saw the post and I thought that it was related to Speed Racer
itilldo is offline
Old 06-23-2006 | 05:19 PM
tomtbone1993's Avatar
it sounds to me like a electrical / safety issue with the motors, I don't think it is wired correctly
tomtbone1993 is offline
La hustler
20
07-13-2007 11:58 AM
Raypanic
06-15-2004 06:50 PM
airshares
13
06-11-2004 01:52 PM
Lsky5101982
2
05-03-2004 06:14 AM
