454 engine/blower help >
Old 03-28-2007 | 08:37 PM
Default 454 engine/blower help
i have an 89 lightning with two 454's in it, turns out they popped the frost plugs when the last owner had it, i pulled both engines, and was going to go through them cause they had 427 hours on them, was also gonna add the weiand 256 blowers, problem is, i dont know much about boats at all, this is my first project, what should i do as far as freshening up the engines? compression? cam? carb? stock heads decent? a guy in town has a set of new 525 heads that he removed from his boat to upgrade, are those a good head for me to upgrade to at a good deal? or should i just keep stock ones?
Thanks for ANY help.
turbosonoma is offline
Old 03-29-2007 | 06:16 AM
monstaaa's Avatar
the weiand if im not mistaken is similiar to the b &m 250. these smaller blowers arent to effecient, as they tend to create alot of heat which defeats there purpose. they do make more powerover a naturally asperated version from a dependabilty stand point, but i might go with something from the blower shop and defineately use an intercooler, as this will keep the charge temp way down and make for a more powerful burn.
as for the 525 heads i dont think they ll work. different bolt pattern, they also have different exhaust i believe.
a client of mine has a pair of 454's with a good valve and bowl job, good cam with out too much over lap, bout 8 1/2 :1. runs a dominator over a b&m with an intercooler. the engines makr a stout 700 h.p on the dynowith about 5-6 psi of boost.
if youd like give me a call maybe i can help you out.
516 779 9642.
monsta
monstaaa is offline
Old 04-15-2007 | 09:49 AM
carney's Avatar
If you don't know much about the motors , I would take them to a good engine builder and let them freshen them and run them. It is hard to make your boat or mine run fast or out front when you can buy a brand new 35 that will run over 100 on pump gas. I have spent lots of money playing with my blower motors , But I do most of my own work and must love taking them apart. But Good luck with what ever you decide.
carney is offline
Old 04-18-2007 | 07:52 AM
bcfountain's Avatar
Registered User
i have a 250 tbs blower on one of my motors and like it.running 5-6 boost.it does make some heat when running under boost for awhile.
bcfountain is offline
Old 04-18-2007 | 10:26 AM
bc fountain : are you running a intercooler along with that.
BOATMAN302 is offline
Old 04-20-2007 | 08:29 AM
bcfountain's Avatar
Registered User
Default tbs blower
no cooler boatman.temps stay around 140-170 depending on the water temp,when i run under boost the temp can get around 180-200.i would like a cooler,but do not have the room.brad
Wateronthebrain
24
12-15-2012 07:21 PM
H2X BOSS
2
05-13-2007 11:58 AM
turbosonoma
10
03-29-2007 10:35 PM
zimm17
9
04-14-2006 06:07 PM
gene
2
01-09-2003 05:26 PM
