Engine compartment Bulkhead >
Old 04-10-2007 | 02:53 PM
35 White Lightning's Avatar
Registered User
Default Engine compartment Bulkhead
Has anyone ever seen a engine compartment bulkhead wood break, I was noticing my starboard trim pumps loose and it looks like the wood behind the glass may have broken and there is a buckle in the glass.
35 White Lightning is offline
Old 04-10-2007 | 03:43 PM
fastoys's Avatar
Saw this on an 05 35x. You use it in real rough water?
fastoys is offline
Old 04-10-2007 | 05:23 PM
Registered User
Maybe before I bought it, it came from NC I only use it in freshwater lakes
Old 04-10-2007 | 07:34 PM
ALL IN's Avatar
i had the same thing.i took the nuts off and used big fender washers and they tightened up and stayed tight you will want a hand with this it's kinda tuff to get to the nuts.
ALL IN is offline
Old 04-10-2007 | 08:46 PM
Registered User
Did you do anything else, was there a buckle in the engine side of bulkhead
Old 04-10-2007 | 10:38 PM
jeff32's Avatar
happened to me once when going down into a big wave ( boat was a a little on the side)from a little jump just before.
Man I thought the boat would break in half! ended up with a cracked bulkhead... Cut it out and did a new one...
jeff32 is offline
Old 04-11-2007 | 08:24 AM
ALL IN's Avatar
no mine was just pumps were loose and when i tryed to tighten the nuts were into the wood so i backed them off and added washers and now it's all good.
ALL IN is offline
mcraymond3
04-04-2014 11:55 PM
gripit
Cigarette
8
08-26-2010 08:08 PM
danh63
Baja
7
02-26-2007 09:33 AM
BWebb
2
04-29-2004 10:25 PM
FindMe
20
10-07-2002 03:35 PM
