Inner tie bar? >
Inner tie bar?
Inner tie bar?
Old 05-20-2007 | 09:08 PM
Default Inner tie bar?
While getting my survey on the '88 29' Fever the surveyor said I should get an inner tie bar, just like the outside one(Latham Marine). I'm new to these boats. Is this common, if so where would I get one? Thanks
twin bravos/454's
prostock85 is offline
Old 05-20-2007 | 10:12 PM
tblrklakemo's Avatar
SeaRay Sundancer
The outside bar you refer to is hydraulic steering. The inside tie bar connects both out drives....you should have both hydraulic external steering and the tie bar if you plan on going fast.
tblrklakemo is offline
Old 05-21-2007 | 08:02 PM
monstaaa's Avatar
it s not going to hurt. but if the one outside from latham breaks it will act as a safety.
if your concernrd from a safety perspective , you can install a lower outside tiebar which mounts to the drives where the trim rams mount to drive.
monstaaa is offline
Old 05-21-2007 | 08:23 PM
I took my Inner out and just rely on the outer...If it breaks I am fuched!
Westcoast is offline
Old 05-21-2007 | 11:41 PM
axapowell's Avatar
Where To
I have an inner tie-bar for sale in the swap shop....I'll make you a GREAT deal!
PM me.
Dave
axapowell is offline
Old 05-22-2007 | 12:43 AM
pm sent
Old 05-22-2007 | 06:45 AM
monstaaa's Avatar
make sure the ears where the inner mounts werent cut off from the factory, as this is normal routine for x tra clearance.
monstaaa is offline
Old 05-22-2007 | 07:43 AM
axapowell's Avatar
Where To
Back at you with a PM.
Can someone post a picture of how this mounts inside the engine compartment?
I think it hooks between the tiller arm and the steering actuator. Thanks.
Dave
Old 05-22-2007 | 08:34 PM
I figured it out, all the pieces are there, I'll post a pic at too where it will hook up to, I just need another pin. The steering ram goes under and over the circled piece while the center is left clear (except for the pin) Thanks again everyone.
MILD THUNDER
4
06-02-2005 03:17 PM
smokinbob
1
02-14-2005 10:04 PM
WetWilly
2
11-21-2002 10:54 AM
Scarab3DMC
04-27-2002 08:30 AM
