Need More Speed >
Need More Speed
Need More Speed
Old 07-27-2008 | 08:27 PM
Registered User
Arrow Need More Speed
I Got A 94 27 Fever And I Can Only Get 70mph Out Of It Looking To Get More Speed Any Suggestions??????
Things I Have Got Or Done Are
Bored 30 Over
Malle Pistons
H Beam Rods
Crane Cam
Reflashed Ecm
Imco Dry Exhaust
Imco Shorty Drive
28p 4 Blade Brovo Prop
I Can Turn It 5,000 Rpm 2 People Full Tank Of Fuel And Get 69-70 Mph And Thats All
FOUNTAINMAN@H.S is offline
Old 07-27-2008 | 08:48 PM
blower?
niceguy is offline
Old 07-27-2008 | 09:23 PM
Id do good ported heads an roller rockers as well. I got good results just fm that on a 502 efi.
lilredboat is offline
Old 07-28-2008 | 07:08 AM
Beak Boater's Avatar
Charter Member # 545
With the numbers you are seeing for rpms and mph, it works out to about 20% prop slip. That is assuming you are running 1.5 gears in your drive. Thats very high prop slip. Sounds like your need to be running a 5 blade prop. You could go up in pitch with a 4 blade, but you will still run high slip #s. Are you on the rev-limiter?
Beak Boater is offline
Old 07-28-2008 | 07:46 PM
Registered User
Hello , Thanks For The Help ... About The Prop No I Am Not On The Rev Limiter I Had It Raised When I Reflashed The Ecm. And 5000 Rpm It Fills Like It Is Pulling Hard But..... Something Is Not Right Bblades Said It Was Slipping Also And Wants Me To Run A 26p 4blade To See If The Numbers Go Down. What Are You Calculating To Come Up With These Numbers I Dont Understand How You Are Comeing Up With 20% ???????
PicChic
11-21-2007 10:46 AM
patricklhill
04-30-2007 06:20 PM
ajl marine
0
09-12-2005 07:35 AM
TGOR
General Racing Discussion
3
03-29-2005 08:07 PM
two-air
Warlock
3
03-15-2002 07:43 PM
