water pickups >
water pickups
water pickups
Old 12-28-2008 | 09:16 PM
johnnyboatman's Avatar
Default water pickups
was wondering where to pull the water from for cooling, was thinking just from drives and a serperate spot for the innercoolers, they have two spots where it pulls water but there where the notched transom is so to me they would get air alot, do u think 1 #10 fitting would supply two inner coolers?
johnnyboatman is offline
Old 01-06-2009 | 08:59 PM
monstaaa's Avatar
depending on the speed of the boat. but -10 sounds very small. if you do seperate pickups use a seperate strainer with a pop off valve and make sure you have plenty of volume going in. the popoff will help maintain spikes during re-entry and the bleed will kepp the pressure down if your really runin speed.
monstaaa is offline
Prater
7
09-09-2008 06:03 PM
teddy38
26
03-13-2007 09:22 PM
bshzba
0
11-21-2006 08:29 PM
Leathl_WS6
Sutphen
0
07-11-2006 07:07 AM
mopower
1
05-15-2004 09:41 PM
