safe rpm to go in to gear >
Old 05-25-2009 | 07:33 PM
Default safe rpm to go in to gear
just wondering waht is a safe rpm to go into gear. cam is so radical that boat stalls @ 2500. afraid to go any higer,
topfueleb is offline
Old 05-25-2009 | 07:55 PM
Registered User
I don't think you can shift into gear at 2500 rpm without welding the cones in the drive. You probably should shut off the engine, put it in gear and then re-start it.
Dkahnjob is offline
Old 05-25-2009 | 08:12 PM
kind of what I was thinking, probley going to change the cam. something with a little more low end and slower rpm driveability.
Old 05-31-2009 | 11:51 AM
Is the the problem with the boat you just bought.
PURPLE HORNET is offline
Old 05-31-2009 | 09:24 PM
yes, its not much of a problem, was aware of a few problems when talking to the seller(got one h**l of a deal) he had been messing with the timming added a msd timming control(advance only??) why i dont know, had some moisture in the v-covers so I did a quick tear down, removing the blower for now and installing a single carb intake. advancing the cam, just detuning some for the summer.
Old 05-31-2009 | 10:05 PM
Any Chevy v 8 will Idle at 1100.. That is the max i would shift into gear at.
mcprodesign is offline
Old 05-31-2009 | 10:07 PM
I always shift when engine is of.....well i did in my bravo boat.
U would need to disconnect the wires for the safety to do so ,,,,but it lasts allot longer that way .
but 2500 ?????,,,,there is something wrong,,,the cam can't be that radical.
I had a dragster cam in my boat before and it was @ 47 timing and @ 1200 RPM idle.
Something is not right !!! And it is not the blower.
DareDevil is offline
Old 06-01-2009 | 07:37 AM
I know its not the blower, have ran top fuel, top dragster and top alky for years, the problem is that the timing. is way retarded like 10* wants to pop back through intake under load. removed the blower for better driveability for the summer and enjoy the boat, this winter will remove and go through that way i know what I have. was just wondering about the gear rpm because I have run jet boats not out drives nevr had a problem with a jet. while on topic how strong and reliable are imco drives? thanks
Old 06-01-2009 | 08:14 AM
I like them .
Old 06-01-2009 | 01:07 PM
I too shift with the engine off every chance I get.
TxHawk is offline
