29 fountain engine? >
29 fountain engine?
29 fountain engine?
Old 06-22-2011 | 01:39 PM
Default 29 fountain engine?
If you were going to get a single what engine would you recommend? ( keep in mind 2003 or newer boat, reliable, and least amount of maintance, so 525, 575, or 600)
24CS Boy is offline
Old 06-22-2011 | 01:49 PM
Mark D's Avatar
HP525...
Runs on 87 octane, boat will kiss the 80 MPH mark and I have had no problems since new in September 2003.
Mark D is offline
Old 06-22-2011 | 02:11 PM
mine has 500HP seems to be a good combo not as fast but reliable
Potomac Fever is offline
Old 06-22-2011 | 02:32 PM
bcfountain's Avatar
Registered User
that would be my choise too.its a carbed motor so most anybody can work/tune it.just be sure to change the valve springs at about 250-300hrs.i have heard and seen horror stories.
bcfountain is offline
Old 06-22-2011 | 03:51 PM
Wouldn't the 2001 be a EFI motor, or did they still make a carb one?
Wildman_grafix is offline
Old 06-22-2011 | 04:02 PM
NWPC's Avatar
575sci. Still low 80s but alot faster out of the hole and to 80. A 525 or 500 won't even be close. Plus you get the blower noise. No issues with my motor since new.
NWPC is offline
Old 06-22-2011 | 06:41 PM
rgrgoog's Avatar
From what I understand and what I am reading the new 525s put out almost similar numbers to the 575s. Your right about no supercharger whine or bling factor. I also wonder if they have the accelration that you get from the 575.
rgrgoog is offline
Old 06-22-2011 | 08:53 PM
mine is an EFI no blower noise and no blown drives. I'm not knocking them, just would not be good for me. The few I have seen in this area are fast but have had outdrive issues
Old 06-23-2011 | 10:26 AM
A normally aspirated motor is going to be under less stress than a blown one. I think you will find you spend very little time at full throttle.
carcommander is offline
