some 32 questions >
some 32 questions
some 32 questions
Old 09-24-2012 | 11:24 AM
Originally Posted by boatnt
wheres a good place to mount a Amp in a 32??
I experimented with this with under the cooler I couldnt get it to work. Then mounted under back seat. Come to find out if your going to do the cooler your going to probably need a 0 Gauge ground wire think I was using a 4 or 6 and it wouldnt work. Needless to say in the middle of the project I wasnt going to take the time and money to go find some wire so it went under the seat.
You need like 2 ohms going to that ground or work.
soldier4402 is offline
Old 09-28-2012 | 02:41 PM
thanks for the info guys...
is the rub rail around the transom thrue bolted?
I need to replace that rear section,,anybody know were I can buy a section??
boatnt is offline
Old 09-28-2012 | 02:42 PM
anybody have a picture they can post of a sunpad from a 32 with the Fountain logo and the 32 in the center of it?
Thanks again
boatnt is offline
Old 09-29-2012 | 08:22 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
no
US1 Fountain is offline
Old 09-29-2012 | 09:37 PM
just screwed i think
http://www.marinewholesaleinc.com/ta.../builders.html
Old 09-30-2012 | 10:01 PM
The other drain is the cooler drain for sure.
Lucky1456 is offline
Old 10-01-2012 | 06:45 AM
no its not,,i purred r/v antifreeze in the cooler and did not drain out of there..
boatnt is offline
Old 10-01-2012 | 01:33 PM
Ginger or Mary Ann?
The large thru hull is the sink drain. the other is for the bilge pump inside the cabin step.
The cooler just drains into the hull. Pizz poor design!
Old 10-01-2012 | 01:41 PM
thanks,,kind of what I thought..I think Iam going to connect the cooler to the sink drain..
boatnt is offline
Old 10-01-2012 | 03:53 PM
Ginger or Mary Ann?
I don't think the cooler will fully drain if you do so. Maybe just enough that a sponge or towel will pick up. To close to call. I thought of doing so too when I 1st bought my boat.
