32 Fever Hull vibration >
Old 01-23-2013 | 04:01 PM
Default 32 Fever Hull vibration
I have a 98 32' Fever, and it has the typical vibration issue when idling out. It seems like it's a lot more pronunced in my boat than others that I've seen and been told about, you can hear it several hundered yards away, it sounds like I have 15 subwoofers in the boat all stuck on one note. It doesn't bother me too much when idling out, I can usually drop the tabs and give it a timy bit more stick, and it gets the swim platfoprm to break the seal with the surface of the water. The problem is idling when I'm at the dock or rafted up, it is bad enough that it gets water completely up the sunpad. Yes, I know it's a boat, and we are at the lake, but I only took it out twice at the end of the season, and each time someone slipped on the wet sunpad/swim platform crossing my boat at the tie up. I'm worried someone is going to break their face and get a lawyer.
After all that long winded explaination, here's my question....has anyone put aftermarket aluminium exhaust on one of these with big blocks, and did it make enough difference in how it sat in the water to alleviate the issue? I have seen threads on here about adding weight to the front, so I did an experiment with some buddies, and it took 3 of us, all right around 200 lbs apiece, standing on the beak to get it to come out of the water enough to make it stop. That's a hell of a lot of weight to carry around that far up the nose. I would be nervous about it starting to stuff the nose in if I hit a cruiser wake wrong. Any advice would be greatly appreciated!!
P.S., I do have silent choice, but need to replace 2 of the solenoids to get it to work. I would rather get it to where I can idle it without the above issues rather than go that route anyway. I like hearing her run, even at idle.
txtraveller2002 is offline
Old 01-23-2013 | 04:21 PM
Mine has the silent choice and its dead quiet @ idle but when I have it above water with a few people on it does the same thing. Nordic 95 has the same boat with quite a few pieces replaced with aluminum and it sits quite a bit higher then stock, maybe a solid 5" or so.
prostock85 is offline
Old 01-23-2013 | 05:17 PM
i would be happy with a couple of inches...5 would be awesome.
Old 01-23-2013 | 05:35 PM
glen george's Avatar
Replace the parts to fix the silent choice.. only option. Or install gibson downturns. I installed emi exhaust and the rear went up about 1".
glen george is offline
Old 01-23-2013 | 05:39 PM
Gotcha....great info...I was actually looking at the EMIs, and that's what I was afraid of, that it would only bring it up about an inch or so.
Old 01-23-2013 | 05:50 PM
My 1st year with my 32 the silent choice exhaust valve was frozen open. I could not take it, I installed these rubber 4" elbows and all was well. I did pull off the silent choice and took it apart and freed it up and works well now. The EMI exhaust i was able to idel around the dooks w/o the rumble when open .
Old 01-23-2013 | 06:08 PM
How many people on board to sink your swim platform and wet the sunpad ?
Interceptor is offline
Old 01-23-2013 | 06:19 PM
I had 10 for the fireworks, 6 on pad and water never made it to the pad but the rub rail seam was leaking quit a bit (3" under water) and the pumps came on every 10 min or so.
Old 01-24-2013 | 01:22 AM
the water line on mine is right in the center of the rub rail. I did the rubrail fix a few months ago, but have yet to be able to test it it, mine was also taking on quite a bit of water....but that's another issue altogether...
When we are tied up in the party cove, As long as everyone with me is staying in or out of the water, I can manage to keep the sunpad relatively dry. The angle the boat sits when stopped is part of the issue, because the sunpad is tilted down some, so it doesn't take much water on it to make it slick as hell. Plus all the pople from other boats crossing, it stays pretty wet all day. Part of the problem to, wich there really isn't a fix for, is the rear of the boat sits so much lower in the water than most that I tie up to, so pople are already having to step down on it. Add some alcohol in their system, plus a little water on the my sunpad, and it gets tricky. I try to keep towels out on it, but I don't want to have to babysit all day.
The vibration issue is just a contributing factor part of the time, I was just hoping to get it resolved regardless, it does get rather annoying in it's own right.
Old 01-24-2013 | 08:06 AM
Where did you find the 4" rubber elbows? Seems like a cheap fix to see if it helps.
sonicss42 is offline
