Prop Help For Non-stepped Fever
Trying to find the right combo for 89 36/38 Fever.
3 blade vs. 4 blade
Mirage/Hydro/Bravo
Props turned in or out
Boat has twin 502 mag efi w/bravo's was setup from the factory with the Bravos not converted from TRS.
Any recommendations?
Thanks,
Todd
3 blade vs. 4 blade
Mirage/Hydro/Bravo
Thanks,
Todd
I have a 1988 8.8 Meter originally equiped with Bravos. The length is shorter but the buisness end should be essebtially the same. I have tried many props trying to find the best one. I found the 4 blades gave too much stern lift and that the three blades are better with the low X Dim on an older boat. I settled on 27 mirage plus and would think the same in correct pitch would work well for your app. Suprisingly 3 blade quicksilvers worked well also. I would like to try some old cleavers in three blade but have been unable to find any. Out had better control than in.
PhantomChaos
06-01-2011 08:09 PM
