Anodize or powder coat, which is better? >
Old 05-30-2005 | 09:40 PM
phughes69's Avatar
Default Anodize or powder coat, which is better?
Anodize powder coat
I bought a Kiefhaefer throttle control off Ebay that is a little weathered. I want to recoat it. Should I anodize it black or powder coat it satin black. Which one will hold up thru the years.
Here is a picture of it.
Attached Thumbnails Anodize or powder coat, which is better?-throttle-control.bmp
phughes69 is offline
Old 05-30-2005 | 10:01 PM
hillbilly24's Avatar
Default Re: Anodize or powder coat, which is better?
Like Too Old Said, anodizing doesn't hold up well in teh sun and you would also have to polich the whole thing first to get to look real good, the only real upside to anodizing is that if you scratch it, it won't spread like powdercoating can.
hillbilly24 is offline
Old 05-31-2005 | 08:17 AM
if your really concerned about protecting it, you should hard-coat anodize it then powder coat it. that would give you the best protection.
marin068 is offline
Old 05-31-2005 | 01:22 PM
Panther's Avatar
Frank's Marine Service
What is best for touching up powder coat. I just had my swim platform powdercoated and some *#CK@SS scrapped the hell out of mine all the way down to the bare aluminum.
I know I can't have it touched up with powedercoat, but what about epoxy?
Panther is offline
Old 05-31-2005 | 01:59 PM
jamess4
Touch up can be a little complicated - if the bare aluminum has been exposed to salt it must be cleaned with fresh water and a salt remover, salt away or chlorrid. Bare aluminum should be primed using a polyamide epoxy. Apply the epoxy in several coats to fill the scratch. Sand epoxy and adjacent surfaces using 320/ 400 grit to promote adhesion. Apply finish paint, aliphatic polyurethane. You can have this matched in products such as DuPont Imron or equivelent. The strong solvent in this paint will adhere nicely to the polyester powder coat.
Note - If you have access to alodine 1200 apply this to bare aluminum before the epoxy. The other option is the old tried and true, put a budwiser lable over the damaged area
Old 05-31-2005 | 02:38 PM
FASTTIMES's Avatar
The handles are Stainless Steel, I had a prop shop polish my handles. You could have the aluminum plates powder coated,painted or polished if you clear coat them..
FASTTIMES is offline
LEOPAJM
06-30-2008 01:04 PM
mopower
04-05-2006 06:34 PM
GregP
02-13-2005 07:25 AM
Luv-N-It
5
10-08-2002 01:06 PM
