Best ever powered single 25-30 >
Old 11-03-2005 | 07:06 PM
  #31
Default Re: Best ever powered single 25-30
i suggest you go out for an ocean test with jo on a pantera 28' single just awesome.they have a new 28' SR model twin stepp in the works .this is a drawing posted on their website with more information listed there.
Attached Thumbnails Best ever powered single 25-30-28_pantera_sr_2006.jpg   Best ever powered single 25-30-28_patriyacht_021.jpg   Best ever powered single 25-30-28twin_05_011.jpg
speed buff is offline
Old 11-03-2005 | 07:43 PM
  #32
Originally Posted by gsmith9898
mount the pipe where? pvc pipe?
Looking at the side of the outdrive, the pipe would be vertical directly above the back 1/3 of the prop with the bottom cut into the anti-cavitation plate of the outdrive. Then it would be supported by some brackets off the top cap of the drive.
The ones I've seen are a heavy rubber hose, like a radiator or hydraulic suction line. Something pretty stiff - i.e. probably has some wire in it.
ECeptor is offline
Old 11-03-2005 | 07:44 PM
  #33
Originally Posted by Superbabi
Go with the SUPERBOAT Y2K..........Best rough water 30' single out there.
Anyone tried a Y2K with a Blackhawk? I assume it wouldn't work as well as a B1 because it couldn't carry the nose.
ECeptor is offline
Old 11-03-2005 | 11:00 PM
  #34
BJM
Went for a ride on the new 29 Activator with a 950 in it today.(WOW) It was snotty out. We did 100 in complete control. No single will beat this new boat in rough water. Nothing! Pantera and Superboat are not in the same league with this boat.
BJM is offline
Old 11-03-2005 | 11:15 PM
  #35
JCPERF's Avatar
JCPERF is offline
Old 11-03-2005 | 11:18 PM
  #36
masher44's Avatar
masher44 is offline
Old 11-03-2005 | 11:23 PM
  #37
BJM
Masher
Jeff and I were talking about the need for a Board members meeting soon
BJM is offline
Old 11-03-2005 | 11:54 PM
  #38
masher44's Avatar
Masher
we are ready.... go to chat!
masher44 is offline
Old 11-04-2005 | 04:54 AM
  #39
JS232's Avatar
Originally Posted by Dave M
I think a Bravo III will fit on the Bravo 1 transom assembly. If you can find someone to loan you a BIII for a few hours why not give it a try?
I think a standart Bravo III woud broke in a few hours. It's design was not intended for performance either... Lots of mph loss...
JS232 is offline
Old 11-04-2005 | 05:00 AM
  #40
JS232's Avatar
Originally Posted by Canada Jeff
I love my 288 Sunsation!
And Dave M has it bang on! Drive in neutral position (depending on X dim), and work the tabs to fly level. Because my X dim on my Sun is rather reserved, I use some positive trim. But when it gets real rough, I go close to neutral.
I believe a dual prop out drive, no matter the make, will slow you down! They are good for planing, and cruising, not top speed.
I would rather sacrifice a few mph's so the ride is always safe... In real rough conditions, 70 down to 50's is'nt that a big sacrifice anyway? For sure, I can do 70... Will I beat the sh...it out of my boat.... Yep... Do I want to?... Nop...
JS232 is offline
