Drive stand project.
Old 12-11-2005 | 12:16 PM
Roger 1's Avatar
Default Re: Drive stand project.
Thanks for the compliments guys. I have a tendency to over engineer and overbuild. In a situation like this where weight is`nt a concern, this philosopy has tended to serve me well. The extra weight, in this case makes for a more stable platform so the stand can be used for doing some work on the drive as opposed to just holding it...or in some examples that I`ve seen, just barley holding it. One of the objectives that I wanted to acheive, was a low center of gravity. That is why the stand is open at the rear to allow the skeg enter the stand. This open end, and resulting loss of strength on that end, will partially explain why I used heavier tubing with additional reinforcements in its construction.
I`ll post more pictures when I get them painted and the wooden top installed.
Thanks again for the kind words.
Roger
Roger 1 is offline
Old 12-11-2005 | 12:43 PM
rbtnt's Avatar
I made a drive stand out of an engine stand after I saw the one that US1 Fountain made. Here is a link to pictures of his stand that I copied.
http://www.offshoreonly.com/forums/s...ht=drive+stand
Here is a picture of my stand. My drives are really that high and I can slide them right in by adjusting the heigth on the tongh jack as neeeded.
www.mtboats.com - Pages of boat related links
rbtnt is offline
Old 12-11-2005 | 03:22 PM
Very nice Roger...
Back4More is offline
Old 12-11-2005 | 03:53 PM
Fine509's Avatar
Hey Roger I never thought that I would be saying this to you but NICE RACK!
Fine509 is offline
Old 12-11-2005 | 07:03 PM
Roger 1's Avatar
Thanks guys.
Roger 1 is offline
Old 12-11-2005 | 07:08 PM
Roger 1's Avatar
Originally Posted by bigd1
I was going to ask if that was aluminum. Not that I know much but I'm told the ability to weld aluminum makes you a stud...
I don`t know about that but it will bolster your self esteem and it`s good for your self image as well..
Roger 1 is offline
Old 12-14-2005 | 05:45 PM
Steve 1's Avatar
Thumbs up Re: Drive stand project.
Nice drive stands Roger in fact the nicest I have seen keep up the good work!
Steve 1 is offline
Old 12-16-2005 | 02:23 PM
Bad Girl's Avatar
Anyone need a custom stand to work on drives? this one I have lets you bolt the upper or lower to a plate and the handle has a 21:1 ratio gearbox to let you roll it 360 deg. and strong enough to work on drive. No clamping on the cav plate.Also an adapter for holding a BW trans to work on it. $200.
an sorry for any threadjacking here. thought of it while looking a yours. Ken
47 Lightning SE
Bad Girl is offline
Old 05-28-2006 | 09:03 PM
Roger 1's Avatar
I thought that I would post an update on my drive stand project. All four are completed and are in service.
Roger
Attached Thumbnails Drive stand project.-drive-stand-yolks-3-medium-.jpg   Drive stand project.-drive-stands-001-medium-.jpg   Drive stand project.-drive-stands-007-medium-.jpg
Roger 1 is offline
Old 05-28-2006 | 09:07 PM
Roger 1's Avatar
A couple more..
Attached Thumbnails Drive stand project.-drive-stands-026-medium-.jpg   Drive stand project.-drive-stands-024-medium-.jpg   Drive stand project.-drive-stands-022-medium-.jpg
Roger 1 is offline
