Removing old exhaust tips
Old 01-31-2002 | 03:25 PM
Wally's Avatar
Were doomed!
Post
Heres another idea for ya pb, Go to home Depot or what ever hardware store is close by and buy some piano wire in a super thin gauge. You can slip it in between the tip and the transome and work around the edges cutting and working your way through the silicone. Should work out good!
-Wally
Wally is offline
Old 01-31-2002 | 07:49 PM
liquid asset's Avatar
Post
Putty knife and a straight screw driver and twist if you take your time it works with no damage
liquid asset is offline
Old 01-31-2002 | 08:48 PM
B.R.S.
Post
The little cheap disposable razor knifes. The are about 1/4" tall and 4-5" long when extended. The kind that have the segments that break off to keep a sharp tip. They bend along way before the segments break. If you are careful you can hold the blade flat against the hull bend it a little with pressure and slice right around the pipe give it a tap and and it will pop right out. Works great but not for the faint of heart.
Old 01-31-2002 | 09:44 PM
formula31's Avatar
Post
Shoot, the piano wire idea is a good one. I have to give it a try next time. Thanks Wally.
formula31 is offline
Old 02-01-2002 | 09:37 AM
Wally's Avatar
Were doomed!
Thumbs up
Sometimes the piano wire trick works good with deck hatches too if you can snake it through. Its like takeing the windshield out of a car then!
-Wally
Wally is offline
Old 02-01-2002 | 09:44 AM
Audiofn's Avatar
Charter Member #232
Post
Take a razor knife and scribe around the outside of it and that should keep your gel coat in tackt.
Jon
Put your best foot forward!
Audiofn is offline
Old 02-01-2002 | 09:46 AM
pb's Avatar
pb
Post
Hey Wally,
Nice idea. I will for sure get these things off. Now I need to replace them. Anyone have a line on 4" stainless steel slanted tips w/ internal flappers.
Paul
pb is offline
Old 02-01-2002 | 09:53 AM
Wally's Avatar
Were doomed!
Post
Paul check your mail.
-Wally
-Wally
Wally is offline
Old 02-01-2002 | 05:23 PM
Airpacker's Avatar
Post
if you have acess from inside the boat,use wooden blocks and a bottle jack to slowly press the tips out.As you pump the jack,ease a blade into the stretched sealer and cut them free.Works sweet evey time.
Airpacker is offline
Old 02-01-2002 | 06:45 PM
Playn's Avatar
Post
Ditto KC Baja, I used the same technique on my 90 Baja...worked great!
Playn is offline
bolgna
4
01-23-2008 06:23 PM
chattviper
02-28-2006 10:13 AM
BajaBuddy
11
05-17-2004 10:00 PM
Kokopelli
11
12-30-2003 01:46 AM
Waterfoul
18
03-15-2002 07:03 PM
