can havasu heat kill speed ?
#31
Good rule of thumb, but its also affected by humidity. About 1.5% loss of power for every 10 degree increase above 70 degrees F. So 40 degree increase equates to about a 6% loss of power or in a 496HO case about 26HP, not enough to srub off more than about 2 mph at WOT. I can tell you from expierence that a problem that is also appearing on a lot of new boats is not enough air intake into the engine compartments at WOT. Remember a 496HO uses about 700cfm at WOT= 700 cubic feet per minute, or a block of air 10 foot by 10 foot by 7 feet every minute! Most new boats should have the engine compartment checked with a sensitive pressure guage to see if they are pulling a slight vacume at WOT. This is just like pulling back the throttle! Not enough air in not enough power out! Check your vent sizes and engine compartment air intake feed size. Remember although not as attactive as flat billet intake vents, scoop vents will inject more air at speed than the flat ones. Also on 496HO's you should prop for about 5000 rpms at Wot, this is where they produce the best prop speed versus max HP. As for most deck boats in the 25 -28 foot range there are very few that will hit 70MPH speeds with stock 496HO's especially in Havasu heat.
I know what the salesman who sells you the boat tells you your deckboat will do 70+ mph., but a little test drive with real loads in real conditions will make honest the real proof for the buyer!
Just some thoughts and info.
Ray @ Raylar
Ray @ Raylar
#32
Ray @ Raylar
Ray @ Raylar
It actually got started because I was asking about running an intercooler on a NA engine to keep the intake temps low. Most agreed that the cooler air would be offset by the airflow restrictions of the intercooler on a NA engine so the converstion turned to allowing the engine to suck fresh outside OUTSIDE air.
It was 95* here and very humid this weekend. I lost about 200 rpm and 2-3 mph when compared to a 75* day with lower humidity.
#33
Originally Posted by CigDaze
600 feet may not sound like much, but the pressure loss is 0.32 psi, or about 2.2%. That may amount to 10 - 15 horsepower.
#34
Originally Posted by noboat
Really? I'm at 1300 feet and I never really considered that I was losing that much hp compared sea level?
#35
Here's a neat calculator.
Start with 77 degrees, 29.235 inches mercury, 0% Rel Humidity, and 0 feet altitude, for a typical standard atmosphere at which engines are tested and rated per SAE J1349
Going to 600 feet, you can expect a 2.5% loss in horsepower, at 1300' expect a 5.4% loss in power.
At 600 feet and 110 degrees, expect a 5.9% loss.
Check it out:
http://www.csgnetwork.com/relhumhpcalc.html
I'm tellin' you guys, it makes a big difference.
Check it out:
#36
Originally Posted by paradigm shift
10 mph loss is high in my opinion. Heat will hurt some HP but not that much. I run a 502 mag mpi with a few upgrades and ran it a couple weeks ago in 115 heat there in havasu. Not much difference when it was 90 early in the day then 115 in the afternoon. I was actually surprised as I expected more loss. I do not like to run it too hard too long in that heat though. I think it is harder on me than the motor.
Bigger HP motors will see more loss. Just my expierence.
#38
Originally Posted by Sydwayz
2 hours to change a tire? I know it was hot, but come on Norty! You have all the toys, but no impact wrench? I changed out a center axle flat tire on the side of I-95 in 12 minutes flat AND I was wearing a business suit! (Took of the jacket of course.) I was on my way to a business appointment, and was taking the boat in for some work afterwards.
No....AAA baby! I was inside with the AC on watching a movie!
Anarchy Powerboats
03-27-2007 09:29 AM
