Ocean Running Techniques
#91
Originally Posted by StillHaulin@61
My "guess" would be that an optimum CG would remain a constant, regardless of sea conditions, and that use of trim settings would be to adjust for the conditions.
#92
But then the question arises, how do you determine an optimum CG?
Some Cats have the motor mounts on "rails" so they can shift the CG so they can set it up for optimum conditions.
#93
I think I might experiment with this CG question this weekend.
I'll set my tab & trim settings completely neutral, and replace enough weight in my bowlocker to create a slightly positive hull attitude providing a fairly stable offshore ride in normal seas. It seems logical that the tabs would then become more effective in bringing the bow down if necessary.
But bringing the bow up is a different issue. At some point, don't the tabs become irrelevant in raising the bow. If they're raised above neutral, how would they provide lift for the bow? It seems that would become the purpose of the outdrive trim.
#95
Originally Posted by BajaRunner
I personally think you are looking WAY too much into it. Learn your boat and how to drive it. If its too rough, look at a longer boat.
#96
Buying a bigger boat is quitting, mastering what I have is exciting!
You should take tres martins class.
#97
When I bought my Pantera the first few times I had it out(early spring) it was really smooth. Tabs up, trim out and running a consistant 70+ mph. As the boating season approached the waters became more sloppy from the additional boat traffic. Lift the tabs too much looking for that last 2-3 mph and the right wave would send you launching.
I constantly noted my tab position vs speed and "looseness" of the boat and made mental notes. After a few hours I knew where the sweet spot was for sloppy water and never brought the tabs up any higher because I knew I'd launch the bow.
I will admit once in awhile I get out of shape because water always changes. But I immediately bring the tabs down, take note of where they are at and leave them under that position.
I finally got to run in some nasty water over the 4th. 4 people in the boat and a full tank of gas and we were running 64-65 mph on top of some confused 3+ footers. I kept the tabs slightly negative and the trim about neutral and throttled the chit out of it.
Maybe I could have squeezed a little more out of it but IMO it wasn't worth it. In that kind of water I don't want to take the chance of injuring a passenger to get 2 more mph. Plus, they were all impressed as hell at how my little boat was ripping through them!
I have ran with a lot of faster boats and in a good 5-6 mile run I am usually ahead of them because they are trying to squeeze every last mph out of it and they end up getting out of shape, recovering and starting over again until they get all out of shape again. And then they just keep repeating the cycle. Meanwhile I am blasting through the slop nice and level!
Okay my post turned into a novel. My point was use the tabs and drive to control the attitude of the boat and with seat time you'll get better/faster.
#99
Originally Posted by noboat
I agree, way too much! Just get some seat time in your boat and you will learn how YOUR boat reacts.
Originally Posted by Bob Saccenti
WHAT TABS?????
Ahhh the good old days
Bobby Saccenti
Bobby Saccenti
Every one else question: have you driven the same model but dif set-up, engines, no cabin Vs cabin? Yes, how noticeable was the dif. Between the “versions” on the same hull?
#100
I appreciate all your suggestions and will use seat-time for my teacher as you've suggested. Actually, my interest was more in understanding the physics of offshore boating rather than increasing my performance. But I've enjoyed this dialog and will let you know how it's going!
