Switchable Exhaust - Why?
Old 08-15-2006 | 02:29 PM
Default Re: Switchable Exhaust - Why?
I read long ago that running with it closed at high RPM will burn the rubber off the flappers. Of coarse I can't confirm that.
29 OUTLAW is offline
Old 08-15-2006 | 02:52 PM
StillHaulin@63's Avatar
I just spoke with a Joanne @ Mercruiser (405-743-6566 option-4) regarding the silent choice option, and routing the exhaust directly thru the Bravo-1 drive.
"There is no predictable negative engine impact other than a minimal power loss due to airflow restriction and backpressure when using the outdrive exhaust option."
I then asked about cruising at 4000-4500rpms and she simply reiterated her comment. Her final thought was "to get the maximum performance from the boat, use the pipes, but for maximum comfort, use the outdrive option ..... that's why we put it there!"
StillHaulin@63 is offline
Old 08-15-2006 | 03:11 PM
satisfactionII's Avatar
Why ????
Because we can and to be cool.
satisfactionII is offline
Old 08-15-2006 | 04:22 PM
Lot's of boats run without thru hull exhaust. Should be no diff.
dave911 is offline
Old 08-16-2006 | 08:17 AM
88Fount33's Avatar
Beak botr
I like my Corsa, but only after I installed them did I find out that they are Illegal in Florida. I switch them off when not on plane, so far so good.
Also,
I found that with them switched off for testing purposes, you can actually hear the engine's internal workings better and can detect detonation easier when they are used.
88Fount33 is offline
Old 08-16-2006 | 08:28 AM
Wobble's Avatar
SORE MEMBER
Originally Posted by SLANDREW
I need mere feed back on this I use them all the time??I just got a call from my marine guy saying not to use them do they damage motors???
Never heard of any damage and it should be a non issue with fuel injection, carb motors may run a fraction fatter, which should still not be a problem.
Wobble is offline
Old 08-16-2006 | 08:29 AM
Wobble's Avatar
SORE MEMBER
Originally Posted by 88Fount33
Also,
Main problem I have noticed on my buddies boat with silent choice is that we can hear our wives talking
Wobble is offline
Old 08-16-2006 | 08:36 AM
88Fount33's Avatar
Beak botr
Yes, that is why when I go on plane, and open them up, it gets real quiet on the verbal front, sometimes I just leave them open when I have to come off plane to pass under a bridge in a no wake zone, so as to not break the spell.
Let's see, cammed up BBC's or chatter about non-sense stuff,,what to do, what to do. My version of "peace and quiet".
Old 08-16-2006 | 08:39 AM
mopower's Avatar
Toxic FORMULA
I enjoyed it on my last boat because I could quiet it down at cruise speed and not have to SCREAM at the person three feet away from me to be heard
mopower is offline
emilsr
Do It Yourself, Boating on a Budget
23
07-09-2008 09:34 AM
rickf
11-27-2007 04:54 PM
RICKY PEREZ
05-19-2006 06:32 PM
buck183
Scarab
7
02-10-2002 11:05 PM
