Great Moments in Cat History >
Old 01-03-2012 | 07:06 PM
  #701
T2x's Avatar
T2x
Allergic to Nonsense
Originally Posted by fastcats
Great thread. Never saw it until this year and have been trying to read the whole thing but never quite get there. I have read posts 1 - 100 about 10 times though while trying to get through it.
The prop rotation information was particularly enlightening. I never considered the torque factor and feel lucky I have never had an incident due to my rotation (in). I plan on reversing my rotation this off season.
There is another variable I would like to get T2X's take on regarding prop rotation. Assume a 36 Skater with #6's.
I would think that the Port side prop blades when turning out would be entering the water above the horizontal centerline due to the fact that the hull angle would deflect the water such that it is higher on the left side of the prop and lower on the right side of the prop. It seems this would be true at least at slow and medium speeds when there is still a reasonable amount of the hull - at the transom - in the water. Over 120, I'm guessing it doesn't make much difference as there isn't much hull in the water even at the transom at high speed.
If the prop enters the water above the centerline when turning out, you would think this would result in additional transom lift. Conversely, when turning in, the prop would (theoretically) enter the water below the centerline, resulting in less transom lift. Perhaps this would require less energy and result in a few extra mph, as I have experienced when I changed from an "outie to an inee".
I have no idea if this is accurate. This is a question, not a statement of fact. I would like to get T2X's take on this as he seems most qualified to confirm or debunk the idea.
You are somewhat correct in this as there are hulls (not all) that gain modest amounts of speed when spinning "in". However that always meant to me that the bottom of the boat needed more bow lift which can also be accomplished with higher prop rake and/or adding some slight rocker (or removing hook) on the planing surface......without having all of the torque issues (in turns and unstable seas) that spinning 'backwards" creates.
T2x is offline
Old 01-03-2012 | 07:07 PM
  #702
T2x's Avatar
T2x
Originally Posted by HTOWER
Here are a few of those that I have in my garage
Please PM me.........
T2x is offline
Old 01-04-2012 | 07:33 AM
  #703
The biggest 'downside' of inboard rotation on a cat is the fact that you are putting the tiebar in compression. Look at one of the big fast cats tiebars. Spinning outboard, you can use a string.
BROWNIE is offline
Old 01-04-2012 | 08:33 AM
  #704
T2x's Avatar
T2x
Which you can also use as a lifeline for the upside down boats that spin inboard.......
T2x is offline
Old 01-04-2012 | 12:06 PM
  #705
Jolley's Avatar
Love this Thread....... Since the beggining.. Happy New year Rich and Darren
Jolley is offline
Old 01-04-2012 | 12:17 PM
  #706
T2x's Avatar
T2x
Right back at ya.......
T2x is offline
Old 01-04-2012 | 07:26 PM
  #707
T2x is spinning in always bad? I have a center console with twin diesels with bravo x drives. I don't gain any speed spinning in but I do get a 10% increase in fuel economy. The boat tops out at 55 but my cruising speeds are 30-45 mph usually 38.
I do think my boat needs more bow lift I installed 1.5" spacers and that helped, I'm running bravo 4 blades now but also have Maximus 5 blades that give me more lift but they seem hard on the drives. Curious as to your opinion.
pstorti is offline
Old 01-05-2012 | 12:33 AM
  #708
Originally Posted by T2x
Once again Merry Christmas to all my OSO friends from Darren and me.
This thread is now 10 years old and counting.........
T2x
...and STILL the best cat thread ever... Happy New Year to you and your family.
Catmando is offline
Old 01-05-2012 | 06:43 AM
  #709
T2x's Avatar
T2x
10%.....??????
Wow! I have no idea why prop rotation in that speed range would have so dramatic an effect on fuel economy....unless you have something causing cavitation from the hull or drives. Is there a hook in the bottom? Put a straight edge (at least 10 feet long) on it and check the entire running surface. Also check the centerline measurements on your drives.
T2x is offline
Old 01-05-2012 | 09:21 AM
  #710
T2x's Avatar
T2x
What were you doing in 1978...?
T2x is offline
