Fountain CC issues
Old 11-27-2006 | 04:16 PM
Panther's Avatar
Frank's Marine Service
Default Re: Fountain CC issues
Originally Posted by animalhouse
Fountain has a good hull, it's a shame they don't take any pride in the way they construct them. All of these problems could have been avoided if somebody took their head out of their azz when they were building it!
I guess that's the difference between a custom boat and a production boat....
Panther is offline
Old 11-27-2006 | 04:18 PM
Ryan Beckley's Avatar
Racer
Racer
Why did you get rid of the YF for a Fountain?
Ryan Beckley is offline
Old 11-27-2006 | 04:20 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
He thought the fish would rather ride on a Fountain.
Sydwayz is offline
Old 11-27-2006 | 04:26 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
I gotta say, I see your point. Just this weekend I have removed some of my cabin interior seating to gain access to areas and am somewhat disappointed to see all the wood chips from drilling the mounting holes still in between the seat panels. Appareantly holes are drilled, then panels are screwed in w/o cleaning up the mess 1st.
The lowest drain hole in the forward bulkhead in the bilge is a good 5-6" above the bottom of the boat. Have yet to figure out how they think any water will drain from inside the hull into the bilge. Good thing I don't allow water to get inside my boat. I also find a bunch of building trash left in the bottom of the hull.
But everything else considered, I love the boat and considered it to be a solid built boat. Just lacking detail to rigging in my opinion.
US1 Fountain is offline
Old 11-27-2006 | 05:09 PM
mr_velocity's Avatar
I'd love to see a 36 Skater center console with a pair of diesels. You can mount the fighting chair on the tunnel between the motors.
mr_velocity is offline
Old 11-27-2006 | 05:12 PM
Hydrocruiser's Avatar
Arrow Re: Fountain CC issues
I do like Fountains and feel the quality is actually up..but I feel your pain. All it takes is one bad one.
I must say I have been looking at the 35 & 38' Formulas. The quality is extremely good and the difference in speed seems to be present in a more solid structure and hull comfort. Not a bad trade-off.
Hydrocruiser is offline
Old 11-28-2006 | 07:02 PM
TEAMBAJA's Avatar
Where do I start? Bilge pumps not hard wired, boat filled up 3 feet of water in the bilge during transport to Florida. We have owned about 15 boats, and this is the first time I have ever seen the bige pump not hard wired to the batteries!!!!
Did I mention that the drain plug was out, but due to Fountains superb construction, the amount of debris and junk left in the boat from construction clogged itup solid!!!!!
Good luck getting either Fountain or Sundance Marine to call you back.............This sucks. Boat is brand new, with 4 hours on it, and all 4 batteries as well as all pumps need to be replaced. Beware if you own one, check your bildge pumps before it is too late.
Are you stuck with the boat?
TEAMBAJA is offline
Old 11-28-2006 | 08:05 PM
FeverMike's Avatar
I own a 2006 38TE Fountain. I have around 120 hours on it so far with out any serious issues. I had some cosmetic marks on the center top tubes and a macerator went out and my dealer Sports USA Marine in St. Petersburgh FL sent there guy out to fix it the next day. Sports USA Marine is one AWESOME dealer!
I had a 2000 29 Fever and had lots of building debri that cloged up some drain holes. I back flushed and vaccumed it out and never had another problem. When I got my 38TE I washed and flushed everything and had very minor building debri. So far the boat has been very solid and runs awesome.
I agree that Fountain needs to address the building debri problem along with some serious clean up of the wire rigging issues. My bildge pumps are wired to the batteries so I do not know why yours were not. If the batteries are on or off the bildge pumps work.
Other than that the Fountain 38TE is one serious well running rig, solid, stable, dry, fast and good on gas.
FeverMike is offline
Old 11-28-2006 | 08:09 PM
animalhouse's Avatar
so far sundance has stepped up to the plate, no help from fountain yet. the boat will be fine, they are replacing every thing that went under water.
animalhouse is offline
Old 11-28-2006 | 08:18 PM
very impressed with the hull, need to adress the outer engines being to high, but other than these quality control issues that should have been avoided t is a nice boat.
