Anyone use oil additives ? >
Old 11-29-2006 | 07:14 PM
vandy021's Avatar
Default Re: Anyone use oil additives ?
Originally Posted by Panther
what about that ZDDP stuff?
That's in all oil as a friction reducer. Conventional or Synthetic. Motor Oil or an Industrial Hydraulic oil.
vandy021 is offline
Old 11-29-2006 | 07:28 PM
mr_velocity's Avatar
hydro posted something a while ago that they reduced the amout of zddp in oil because it was screwing up cats. Ever since then I've been adding Valvoline Syn Power oil treatment in my Mobil 1 fills. The Redline fills get nothing additional.
Bern, your boat always had top shelf Amsoil....if you like amsoil that is. I never cared for it.
mr_velocity is offline
Old 11-29-2006 | 07:48 PM
berns29scarab's Avatar
Hey Garry...was actually going to ask you how much of the service history you were involved with and or a part of. Shoot me a PM or an email if ya could thanks.
berns29scarab is offline
Old 11-29-2006 | 10:43 PM
Just say no to oil additives. If the oil needed them the oil manufacturer would have added them at blending.
http://www.bobistheoilguy.com/images/lucas/lucas.htm
o2man98 is offline
Old 11-29-2006 | 11:42 PM
stecz20's Avatar
Originally Posted by berns29scarab
If my pockets were as deep as yours i wouldnt ask these kind of questions...i just run it til it blew then rebuild or replace...SO PUT A LID ON IT THERE SLICK !!
i could have you killed for such ill manners...
stecz20 is offline
Old 09-21-2014 | 10:51 PM
Originally Posted by stecz20
stop asking dumb questions????
That is quite an impressive avatar
mcprodesign is offline
Old 09-21-2014 | 10:52 PM
Seriously. Has anyone tried "prolong" or any other molecular bonding lubricants?
Old 09-22-2014 | 06:42 AM
I ran ZDDP additive in my 575sci with flat tappet cam. I used it with 15/40 rotella and never had a cam issue. Running 10psi boost I changed the oil a lot due to fuel dilusion and could not see spending money on synthetics or racing oil of any type. Oil pressure was always rock solid.
My $.02
JRider is offline
Old 09-22-2014 | 07:19 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I am a fan of Lucas Oil Products, but I don't use it to extend my oil changes. I put the appropriate Lucas oil in anything with an oil pump.
Sydwayz is offline
Old 09-22-2014 | 07:40 AM
The above statement is TRUE. Regarding less zinc in today's oil. That statement is also true. Not because it screws up the cats, but because the moron's thought it could screw up the cats. Anyway, most of the newer versions of API oil have an SN rating. The SN rating is the reduced zinc. If it's the older SM rating, which still exists in certain viscosities because it meets some of the import specs that has plenty of zinc. And of course "racing" oil is loaded with zinc, etc.
benjen is offline
