Prop Spin??
Old 05-31-2007 | 04:47 PM
Default Prop Spin??
Prop Spin or what??
I have a 2001 Wellcraft Excalibur 26ft– 496 built motor –Dyno shows 570 HP. It runs great on plane running at high speeds, at cruzing speeds in choppy water I have allot of RPM movement. Basically if I’m running just on plane 2600 to maybe 2900 RPM range. The RPMS jump up and down buy about 500 R’s or so. It is almost like they go up and down as I go over the waves. If its calm out this never happens. Just wonder if that was somewhat common. My old boat the R’s never change regardless of conditions unless you moved the throttle. I’m running a 24 P Bravo1 prop - Is this normal or ok at least?
JBoat is offline
Old 05-31-2007 | 07:47 PM
Fenderjack's Avatar
Pirate of the Chesapeake
I would have to think that it is because the prop is slipping or cavitating just a bit when in the choppy water. What was your previous boat, the wellcraft X probably has a higher X dem so the drive is already closer to the surface, then your old boat..
Fenderjack is offline
Old 06-01-2007 | 05:17 PM
Possibly - the old boat was a wellcraft eclipse. more of a run about. I just have never seen any boat have the rpm range move so drastically. Should I be considering a diffrent prop ? I can deal with the up and down but I cant think its great for the motor.
JBoat is offline
Old 06-07-2007 | 06:10 PM
any more input boys . i want to make sure im not soing any damage running her like this. All else seem to be up to par.
JBoat is offline
sierraspringsjay
3
05-27-2008 04:20 PM
tgersx
8
05-30-2007 02:08 PM
tgersx
Drives and Lower Units
1
05-29-2007 08:32 PM
BillR
16
09-15-2002 06:26 AM
