Fastest 28 Nordic Heat
Old 07-03-2007 | 02:29 PM
First you have to take operating conditions into consideration. My boat ran mid 80's all last year here. I took it to a radar shootout at Cumberland last year and it ran 89.2 at 5600 RPM. I pulled the engine and dyno'd it at 770 CHP at the 5600 RPM I was turning it, 815 AT 6000 rpm. Of course boating here you're losing about 8-9% power to the weather. I've set up quite a few 28's and the numbers work out pretty consistently. I suspect Steve is making much more than 700 HP. Steve ran my prop at Cumberland and got 90+ @ 5700 If memory serves me correctly. The last run I made with it here was 92.2 @ 6050 RPM. But that was on glass water and 95+ degree temps. You can see from the numbers the slip was much greater. That's because the boat is glued to the glass water. Run the same situation on 1-2' Chop and the speed would come up 3-4 MPH at that RPM, which is more indicative of the way Steve's ran at Cumberland (nice chop). The 28 Nordicflame is running has never seen true top speed, since it is used at high elevation. Also, remember my boat is an open bow. The balance on the boat is different than the closed bow version. From all I've seen the closed bow boat is a couple of MPH faster, all else being equal. Like I also mentioned I believe the ITS is costing me a couple of MPH. So, you add all that up it could equate to the differences we see.
Bob
Originally Posted by Young Performance
Some of these numbers aren't adding up. Steve just dynoed his motor at just over 700(I believe) and he is running low to mid 90's on GPS.
Nordicflame is running almost 100 with 300-400 more hp
Bob has about 200 more hp and runs about the same as Steve.
I'm certainly not calling anyone a liar or starting any $hit, just trying to figure out what this boat will run. I'm sure there are some differences in setup, weight, drive height, conditions etc., but there are some BIG differences in these numbers.
bobl is offline
Old 07-03-2007 | 03:29 PM
I am just looking for some accurate numbers. That was the purpose of this thread. I NEVER said anyone was BSing. The numbers just did not add up. Nordicflame is supposedly making 300-400 more HP than steve, yet only running 3 mph faster. Doesn't add up does it!!!!
The number that is suspect to me, is Nordicflame's HP claim. I find it very hard to believe that a 548 ci motor makes over 1000 hp with 6 psi of boost on pump gas. No one else can seem to do it.
I think that steve's numbers are pretty close to where they should be. His dyno run made somewhere between 700 and 750 hp( I don't remember exactly) He added about 125-175 hp. That could easily add 15 mph, if he made 750 hp. Not to mention, that motor is a 502 with a small blower. With the boost that he is making, that is about what that motor should make for HP. There is nothing wrong with that and by no means should he be disappointed.
I didn't come on here to get in a pi$$ing match. I am not trying to outrun anyone. Just want to know what to expect for speed, ride quality and handling.
Young Performance is offline
Old 07-03-2007 | 03:33 PM
I agree with you Bob in that conditions will change speed quite a bit. Weight, temp and altitude will also play a big roll.
Old 07-03-2007 | 03:56 PM
I built the 540 for that 25' Rage we had at Cumberland. It made 1005 HP at 8 psi boost with an M3 procharger. I dropped the boost to 6.5 and made 925. The engine in Nordicflames boat is similar, but has better heads and most importantly an R-tech intercooler. That's where he is coming up with his data. Remember, as has already been said. That boat is used at over 5000 ft. elevation and still running well into the 90's. He's never gotten to set it up and do any testing at sea level. So, those numbers don't compare directly to what we are doing.
Using the speed calculator from BAM marine's website validates virtually all of these numbers that we have documented. My boat ran 60 with a stock 375hp/496. Plug that into the program and change the HP to 770....It gives you 86 MPH. Hmmm, exactly what it ran. Steve's numbers work out to well over 800 HP. I also dyno'd a Raylar 496 at 553 and the boat ran 72.8. Again the numbers work perfectly. Nordicflames boat has seen 97(on the rev limiter) and the program says 1000 HP to get there. Again numbers seem valid.
bobl is offline
Old 07-03-2007 | 04:40 PM
Nordicflame's Avatar
No pissing match here...Geez man; we're just giving you numbers.
103 w/1200hp Paul Phaff
97+ w/estimated 1050+ (out of prop and 156kPa boost ~8.3 lbs @ Havasu)
93+ w/estimated 900+ (140kPa boost ~6 lbs @ 5000 feet)
92-94 w/923hp FTM motor
92-94 w/700hp Steve Zs 700+
84 w/ 734hp Larry Peto built 496HO Whippled
76 w/575SCi
73 w/553 Raylar
65 w/425 MAG HO
60 w/375 MAG
These are confirmed numbers...
I'm sure there are exceptions but you wanted a general baseline so there you have it.
Nordicflame is offline
Old 07-03-2007 | 05:13 PM
Indy's Avatar
Member #154
76 w/575SCi
73 w/553 Raylar
65 w/425 MAG HO
60 w/375 MAG
Well..I can confirm the 65 w/425hp HO Actually I saw a max of 67 going downhill one day
Indy is offline
Old 07-03-2007 | 06:09 PM
SeaRay Jim's Avatar
Originally Posted by In2Deep
I guess my 63.5 MPH top-end doesn't qualify.
I used to kid BoatingBent (pre-Raylar ) that those speeds are great for keeping up with my Searay. We ran exact times at a radar run at Table Rock in 2005.
I can't kid him anymore, so I need a new target. Just kidding, 63.5 MPH would keep up for quite some time before I got too far ahead.
SeaRay Jim is offline
Old 07-03-2007 | 11:43 PM
Nordicflame
Thank you for taking the time to post all of the numbers. Yes, Steve's does seem out of whack with everyone else's. However, I had just used the same dyno maybe two weeks prior and it was on the money. That doesn't mean it can't change. That is why I was believing Steve's numbers so much.
It also seems that the boat starts taking a bunch of power once in the 90's. Best I can tell, it starts taking almost 20 HP per mph. In the 60's and 70's, it seems to take 14-15 hp per mph, which seems about right.
Sorry if it seemed I was being an a-hole. Just want some accurate info so I can tell my customer what to expect.
Also, this boat ran 72 with a 496 Mag HO
Thanks, Eddie.
Old 07-04-2007 | 12:20 AM
articfriends's Avatar
The Heat runs very nicely at speeds up to 100. As with any boat you must pay attention
I've only known of one true Heat that has run 103 and that was on the Ohio river I believe. He could not keep a B-Max together however. That was with a Paul Phaff 1200 motor that they had pullied and fueled for power
I built a 548ci ProCharged EFI motor with an R-Tech Supercooler that is pushing a Heat 97+ and running out of prop at Lake Havasu. I have no doubt that it will hit the 100 mark with the right prop. It runs a strong 93 mph here at 5000 feet elevation every day. Appx hp 1000-1100.
It has a Max Machine drive and every time we drop elevation it seems to have a drive issue of some sort. To be expected I guess
925 should put you in the low to mid 90 range. When you get there, ask us about props because I think between us we've tried them all
It will take more than 925 to be the fastest ever. We are only running 6-7 lbs so we have some room to play
What props are you using to get your best speeds,I'm running 944hp in my baja 272 (540 w/m-3 at 10 psi boost,afr heads),runs 89.8 fully loaded w/30 pitch labbed on rev limiter at 6000,runs 92.8 (best run ) light with 32 merc labbed 4 blade at 5700-5800.My motor was probably around 900-920 hp in the boat,on the dyno the innercooler was getting pretty cold water on the big number pulls. Curious what kind of props your having luck with. I tried a maximus last year,boat was a real slug and sheared off a max worx prop shaft after a few passes. In comparison to stock speeds my boat only ran 62-63 mph w/stock 502,Smitty
articfriends is offline
Old 07-04-2007 | 07:28 AM
Indy's Avatar
Member #154
Thanks, Eddie.
Strange...I tried many prop combinations in all temp ranges, wind/current directions and barely got 67 And that was only ONCE Most people I know with the same boat got no better. A 5 mph difference is huge. Are you sure that number wasn't going over the waterfall?
Indy is offline
