Marine warrenty.HUH
Old 07-31-2007 | 12:47 AM
  #61
What gear oil you using?
So far I had good luck with the GL-5 Mobil 1... 75w-90
Back4More is offline
Old 07-31-2007 | 01:26 AM
  #62
articfriends's Avatar
I haven't had any gear oil that seemed to help more than any other,I always run synthetic and have tried everything. Currently I am using royal purple 75/90,I ran a set of gears with the 75/140 or 80/140 royal purple. I thought maybe the thicker gear oil would help keep from chewing up the gears,I drained it out and changed it every weekend but the gears (stock ones and other sets that I tried things that didn't help their life with like extra heat treating) still failed. I did notice however after swutching back to lighter oil I seem to have found 2.5 mph more which seems impossible.
Sorry to Hi-jack this B-max thread,I am just trying to help others who have the same problem getting outdrive gears to last. It would be nice to have a warranty that covered these lowers failing so often but in my case I would have needed to buy 2 B-max drives,so that I had one to run while I shipped the other one off for new gears,it would be better to be able to just run it considerably longer without the gears failing,warranty or not,Smitty
articfriends is offline
Old 07-31-2007 | 07:26 AM
  #63
Beak Boater's Avatar
Charter Member # 545
Originally Posted by rackster
The drive shaft , in the lower, broke in the splines above the pinion gear. This damaged the gear set, as well as cracking the lower housing. The lower gears do show signs that they were "giving up" as well (stress cracks and pitting on gear faces). I think that the housing is repairable, so it will need a drive shaft, gear set, bearings, and seal kit to put it together.
This is a single engine application (29' Fountain), so the drive carries 100% of the load all of the time. I did call Dean, when we were researching drives, and was assured that this was the "last drive that we would ever need", for this application. It was understood that there may be some speed loss(due to gear ratio change). That was acceptable, as a trade for reliability. That is why we decided to go with the B Max.
I understand warranties, and have been in the "boating" industry at every level. I do not feel that Dean owes us 100% coverage, under the circumstances (second owner, 6 days out of warranty per Dean). I would expect that some kind of offer to "share the cost" could have helped both of us. He could have offered a discount on parts,labor, or both and still not lost money in honering a warranty, that is less than a week out. This could have turned a bad situation, into some good publicity for his company. Not only that, it would give him an oppurtunity to inspect the failed part, and determine if changes need to be made. That's very important, when you have a failure where there shouldn't be (may need to change parts or modify warranty).
I now have the second B Max on the boat, and have to wonder...when is it going to let us down??? There is no confidence in this drive now.
That is my side (opinion) of this situation. I am not bashing Dean, or his products. I just wish that our "reasonable expectations" had been met.
Thomas, sorry to hear about your problems, went through the same with IMCO at one time. When the drive broke, I hope it didnt damage that stripper pole.
Beak Boater is offline
Old 07-31-2007 | 08:43 AM
  #64
Thanks Beakboater. This is Chris. We are working to resolve this. The pole is still very functional. That seems to be the least problematic upgrade that we've done to the boat .
rackster is offline
Old 07-31-2007 | 09:50 AM
  #65
The Bmax is basically a Bravo with larger upper case(water cooled), gears, some larger bearings and shafts....
It uses the same clutch cone assy., pinion bearings, and seals.
The lower back then when I got mine were XR lowers with the larger vertical shaft.
Again, with those treated lower gear sets I'm looking at a near perfect setup with the Bmax uppers .
Old 07-31-2007 | 09:54 AM
  #66
Hey Chris....hope you get the problem worked out. If all else fails you can hang a sheet on the stripper pole and have the Worlds Fastest 29 Fountain Sail Boat.
Old 07-31-2007 | 11:12 AM
  #67
Panther's Avatar
Frank's Marine Service
Pretty much sums it up! Here are my uppers after 70 hrs last year, notice there is barely a wear pattern on the gears and the size of the gears.
Attached Thumbnails Marine warrenty.HUH-gears2%2520001%2520%2528medium%2529.jpg   Marine warrenty.HUH-gears2%2520005%2520%2528medium%2529.jpg   Marine warrenty.HUH-gears2%2520006%2520%2528medium%2529.jpg
Panther is offline
Old 07-31-2007 | 11:14 AM
  #68
Panther's Avatar
few more
Std. XR upper gear is about 3" in diameter, BMax is around 5".
Attached Thumbnails Marine warrenty.HUH-gears4%2520001%2520%2528medium%2529.jpg   Marine warrenty.HUH-gears4%2520003%2520%2528medium%2529.jpg   Marine warrenty.HUH-gears4%2520004%2520%2528medium%2529.jpg
Panther is offline
Old 07-31-2007 | 09:47 PM
  #69
The boat owner called Dean today. Apparently Back4More misunderstood, because Dean's position is the same. NO WARRANTY, and no consideration for not living up to the "sales pitch". He did have the parts, and they will be sent to the customer(at full price).
It is very dissappointing to me, because I did the research for my customer, and recommended the BMax, based on Dean's claims. Now we have no confidence in the drive or the manufacturer. I guess we are STILL looking for an alternative to broken Bravos . At least we have two, it's just hard to change them in the water, 100 miles from the shop.
rackster is offline
Old 07-31-2007 | 10:34 PM
  #70
Bullhead's Avatar
Rackster that sux.....I know you and Thomas had high hopes for the B-Max product....others on here seem to have good luck with it so maybe you will now....appears they make a decent product but don't handle issues very well...good to know before doing business with them...see you in reggieville thurs
Bullhead is offline
