Help with boat choise.
Old 11-23-2007 | 09:10 PM
Originally Posted by PJDiesel
That is the one that stuck out to me as well.
Used to be a race boat, redone by Formula. No cuddy tho. No trailer. Twin 500's
PARADOX is offline
Old 11-24-2007 | 08:59 AM
TeamSaris's Avatar
Driver-441
Racer
If your worried about weight Hustler and Fountain will be the lightest
TeamSaris is offline
Old 11-24-2007 | 10:08 AM
RHC's Avatar
RHC
The most important question has not been addressed ???? What kind of water do you boat in,,, Offshore ,, Great lakes Rough or inland rivers and smaller lakes ,,,,,,,, ?? now ,, how much gas do ya want to use each weekend ???/ only then can you pick the best boat for your enjoyment ! good luck and be safe out there ,,
RHC
RHC is offline
Old 11-24-2007 | 10:12 AM
Good points RHC
Mostly offshore in Fla. Near Tampa and also Ft. Lauderdale.
Poker runs. weekend excursions.
Gas. no matter.. it will go up to $5.00 per gal. next summer.
Any hybreed, or elecetric boats??
PARADOX is offline
Old 11-24-2007 | 10:42 AM
Registered User
If you're trailering and don't have or want to have a dedicated tow vehicle or a dually as a daily driver, stick with under 35'.
It doesn't really matter which of those boats you buy as long as you know what you're getting. If the nicest one on the list has rotten stringers, hidden damage that was poorly patched over or a mostly worn out drivetrain, it will ruin your ownership experience.
Understanding your expectations is important too. Buying a boat and then wanting 15 more MPH can be alot more expensive than just finding the boat you want in the first place.
As far as your list- there's a pretty broad range on there. Your best investment (if you can call it that with a straight face) is a Cig. They typically don't break or rot, they're well-rigged and stylish. They also hold their value better than just about everything else. Best of all, when someone asks, "Is that one of them Cigarette boats?" all you have to say is "Yes". A 35 will tow behind an F250, mash waves that alot of larger boats will bounce off of and go fairly fast without 1200 hp blower motors.
Chris Sunkin is offline
Old 11-24-2007 | 11:50 AM
Boomer 880's Avatar
How about the new AT 33' listed in the classifieds for $169,900.
Boomer 880 is offline
Old 11-24-2007 | 12:11 PM
Thanks Chris
YOur comments make good points.
Quote >>> Understanding your expectations is important too. Buying a boat and then wanting 15 more MPH can be alot more expensive than just finding the boat you want in the first place.
I been in that shoes with the Avanti, Great hull, short on HP, so I was working on getting it faster, then all $hit happened.
PARADOX is offline
Old 11-24-2007 | 02:35 PM
I'm a little suspicious of that ad. 2009 model?????
I guess it could be Pat's dealer friend?????
Griff is offline
Old 11-24-2007 | 02:42 PM
Originally Posted by BBB725
2001 382 Formula, depending on condition, hours, etc.... $99,000 is a great buy
I am not a fan of Formula(s), but at $99K, for a 2001 Formula 382, that is a decent deal, if the boat is clean.
Smarty is offline
Old 11-24-2007 | 03:22 PM
That AT has no paint,graphics, and the 496 HO's.
I really want some more horses in a 33'+ boat.
To hard to make the 496's put out more HP, unless you go into the guts. Great motors for what they are designed and used. Not enough for some serious offhore, in deep "V"'s.
Superchargers are risky with the interior set up on the 496.
Smarty.... the boat (Formula 382) has no cuddy, Race set up converted to "poker run" style. It's on my "hot list" but you have to climb over the bolsters to get back to the rear of the the cabbin.
PARADOX is offline
