Dyno info needed
Old 03-18-2008 | 05:20 PM
Ron P's Avatar
Enjoy the show
Default Dyno info needed
Who makes the best and most accurate Dynos?
In NJ, who would you take an engine to just to have it run on a dyno?
Ron P is offline
Old 03-18-2008 | 05:55 PM
Strip Poker 388's Avatar
Rob
Allways heard the Freud brake then the http://www.stuskadyno.com/
software
http://www.depac.com/
you tuning or just breaking it in?
Strip Poker 388 is offline
Old 03-18-2008 | 06:01 PM
If it hasn't been properly calibrated, then none of them. They will all measure consistently and do the proper break in, and show you performance increase, decrease, power band, fuel etc. Whatever you want to know, but if you are comparing one engine to the other, then the engines have to be run on the same dyno for comparison, or they have to be run on a calibrated and certified machine.
Curious to see what the GURU's have to say about my opinion.
Are you wanting to buy one for yourself, or what?
jeff1000man is offline
Old 03-18-2008 | 06:28 PM
JCPERF's Avatar
Call me jack***
JCPERF is offline
Old 03-18-2008 | 06:33 PM
Superflow.......and I have one.
mrhorsepower1 is offline
Old 03-18-2008 | 06:39 PM
scarabman's Avatar
Hey Ron,
In NJ, you go to Johnny Blewett out off Rt 70 just outside Lakewood. He is very good. If you want more HP go to Kurts though. His Dyno always makes more HP than anyone elses
scarabman is offline
Old 03-18-2008 | 06:45 PM
Originally Posted by scarabman
Hey Ron,
ITS A SKATER NATION !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 03-18-2008 | 08:45 PM
Your question is accurate dyno - you need an AC electric brake/absorber or Eddy Current not a water brake, these are the most accurate and the most responsive.
AC's are basically a generator with a rheostat on a load bank.
As far a brands??? We had both Clayton and Superflow water brakes. The Clayton was more accurate and could hold a load much better than the Superflow.
The electric brake, don't remember a brand, it was built with peices over the years.
HabanaJoe is offline
Old 03-18-2008 | 09:13 PM
Hey Ron,
He used to do work on Penske's IROC motors. Very good, very helpful.
He puts in real numbers, fuel weight, temp, pressure, ect. so his outputs are real numbers.
MOBILEMERCMAN is offline
Old 03-18-2008 | 09:52 PM
Wazzup Racing's Avatar
Registered User
If you are looking to compare a 525 to a base line. We have run a dozen on the same dyno in Wall twp.
Wazzup Racing is offline
dreamer
Apache
2
04-24-2005 09:25 PM
Cig35Mistress
02-10-2005 09:45 PM
tomcat
9
07-26-2003 11:11 PM
Bad to the bone
4
02-26-2003 10:41 AM
IceAngel
08-15-2002 02:00 PM
