Blower on top or charger on the side? >
Old 07-17-2008 | 10:28 PM
Default Blower on top or charger on the side?
Question, I don't know what the difference is will someone explain it to me. I see boats with a whipple set up like a ac unit, then I see big belt blowers on top? Pros and Con's?
nova26 is offline
Old 07-17-2008 | 10:50 PM
tblrklakemo's Avatar
SeaRay Sundancer
the whipples, B&M's, etal are on the top(except 500efi) and the vortechs are on the side
tblrklakemo is offline
Old 07-17-2008 | 11:19 PM
ZXXX Donzi's Avatar
Originally Posted by tblrklakemo
the whipples, B&M's, etal are on the top and the vortechs are on the side
Actually Whipple made a side mount. I will try to dig up pics
ZXXX Donzi is offline
Old 07-18-2008 | 12:31 AM
articfriends's Avatar
Your really talking roots vs centrifugal. Roots = eye candy,centrifugal =effiecient hp. I'm partial to centrifugals because I have one. It takes a TON of hp to spin a roots blower (parasitic loss). My boat cruising at 3800 at 58-62 mphwill still get around 2 miles per gallon and can run almost 100 at wot,my bud with a roots gets closer to 1 mpg cruising and runs 75 mph wot but the compariso's not apples to apples,Smitty
articfriends is offline
Old 07-18-2008 | 09:48 AM
So a whipple mounted charger is better for a recreational boater? Better on gas?
nova26 is offline
Old 07-18-2008 | 10:54 AM
Generally when you say whipple that means roots.
roots style blowers make more boost at low RPM's. but they cost you in efficiency.
If you have a BIG V, or a Cat hull, roots may be better to help get the boat on plane. If you have a normal V or small V, or even a small cat, Vortech or ProCharger is better because you will get better efficiency and less cylinder pressure at low RPM's.
VetteLT193 is offline
Old 07-18-2008 | 11:08 AM
Not bashing or anything but if Centrifugal superchargers are so great why doesnt any body build one as an engine package vs. just being sold as an "add-on" modification? Also isn't a Weiand, B&M and Moonyham a "roots" (i.e. rotor) type blower and a whipple acually a "screw" type? Although they look similar from the outside (except one gets air from the top and the other from the rear) they are quite different inside.
Mike
Michael Garibay is offline
Old 07-18-2008 | 11:10 AM
SeaRay Sundancer
Mike
r-tech does...you can get it with a konrad ace too
Old 07-18-2008 | 01:15 PM
One thing that also comes into play between the Roots and Centrifugal is the amount of stress that is placed on the drice. The roots, being that it makes more power down low, can put more strain on the drive.
Run_em_hard is offline
Old 07-18-2008 | 01:16 PM
R-Tech makes one nice setup...expensive but awesome.
