Nortech Off The Trailer On I 75 >
Old 10-10-2008 | 12:19 PM
  #91
Originally Posted by scarab kv
Yup. Myco for my old barge.
I like your old brage. My tub just went up for grabs.
PARADOX is offline
Old 10-10-2008 | 12:25 PM
  #92
Thanks. Looks like you've got a fleet.
scarab kv is offline
Old 10-10-2008 | 12:27 PM
  #93
Originally Posted by wrinkleface
Terry, is that a new 50??? Rumor control Dude, let us know! Thanx
Why control rumors? Isn't it more fun just to let speculation run rampant?
salesmanship is offline
Old 10-10-2008 | 12:38 PM
  #94
Strip Poker 388's Avatar
Rob
Originally Posted by Chris Sunkin
2" straps are 10K/lb test each. And, you're not lifting the boat, you're holding a trailer to the bottom of it.
A good amount of downward tug with 2 straps up front and one on each rear corner bcreates alot of bunk friction that holds it from sliding as well.
What about a shock load,bursting strenth,like if the toung dug in sudden stopped. It it supose to still hold it?
I would bet these yellow strap hooks would straighten out
I use the blue strap style hooks.
Attached Thumbnails Nortech Off The Trailer On I 75-zzzz.jpg   Nortech Off The Trailer On I 75-zzz3506%2520ratchet%2520tie-down.png
Strip Poker 388 is offline
Old 10-10-2008 | 12:57 PM
  #95
socalstone's Avatar
Anyone know how fast he was going?
Seems like straps may have saved him at or below 30mph, but at highway speeds there's no telling what could have happened.
Straps are a must, but that trailer failed huge.
if it was built that lame, I would venture to guess the strap connections welded or bolted to the trailer may not have been up to snuff either.
socalstone is offline
Old 10-10-2008 | 01:13 PM
  #96
Originally Posted by maritaltension
props come off every time ? just in case ? theft ? how much were those props worth on the nortech on the road ?
if you ask me seems like the guy was a newbie , i've never understood 300k and up boats on cheap traillers , are you kidding me ? it seems to me like if you have that money to spend the boat automaticlly goes on a manning or myco.
my boat is practicly worthless and it still has a cable ,strap, and saftey chain on the front and 2 big azz 3" straps on the back , and where the ratchet wants to hit the boat i got these terrycloth waxing pads that simply slide in between the ratchet and the fiberglass ,works awsome for the last 12 years
Cleavers are very pricing.....you are looking at 6 to 10k on a set. I don't want them walking away on top of being dinged by debri on the road.
40FlatDeck is offline
Old 10-10-2008 | 01:45 PM
  #97
wrinkleface's Avatar
Originally Posted by PatriYacht
For a minute there I thought it was Tracy's boat.
Thanx 4 that thought Bubba!!!!
wrinkleface is offline
Old 10-10-2008 | 01:56 PM
  #98
DONZI's Avatar
Originally Posted by DaveP
Should have had a MYCO
http://www.certifiedsales.com/listings/YS080092.html
DONZI is offline
Old 10-10-2008 | 01:58 PM
  #99
Dock Holiday's Avatar
Charter Member #34
Lesson to be learned.
1) Always have enough truck for the towing job.
2) Always have enough BRAKE both truck and trailer.
3) Always have a trailer that carry capacity exceeds the capacity of the load.
4) You cannot ever have too many straps or too heavy of a strap.
5) Slow down and allow more distance when weather and traffic conditions require it.
6) Double check all connections, brakes, lights, tires and straps before pulling out.
7) Say a prayer before leaving that someone texting while driving does not wreck you.
Proper Planning Promotes Proper Performance
Piss Poor Planing Promotes Piss Poor Performance
Dock Holiday is offline
Old 10-10-2008 | 02:54 PM
  #100
Mbam's Avatar
Offshoreonly Advertiser
We always had it as the 6 p's
Prior Planning Prevents Piss Poor Performance
Mbam is offline
