BIG Time motor problem ...any ideas  ????? >
Old 08-18-2009 | 02:49 PM
  #331
Panther's Avatar
Frank's Marine Service
Originally Posted by MER Performance
Water being injected would be of great concern to me the water droplets in the air are bad enough.
Thanks for your time! Mark
My fathers turbo engines built by Flagship used a water injection system back in the 70's and it significantly reduced detonation under boost.
Panther is offline
Old 08-19-2009 | 08:16 PM
  #332
MER Performance's Avatar
Running Hot, Understand 14 # boost. The pistons I was referring to was the one in the white box with some Gray Goose. Can you tell me your HP and torque?
MER Performance is offline
Old 08-21-2009 | 08:27 AM
  #333
Theres some Badd Azz Turbos on the dyno now in Michigan and there making some huuuuge #s sounds like a nice winter project
Old 08-21-2009 | 08:55 AM
  #334
B38
They have been useing H20 Injection for years on Diesel Tractor pullers. Big Meth injectors and H20 Injectors side by side between the valves if I remember rite. Lots and lots of Break Hp out of those once diesel engines. Enough to pull the crank out every time damn near. Who Hoo, some power there.
H20 injection is proven in my eyes.
B3
B38 is offline
Old 08-21-2009 | 01:10 PM
  #335
Its great if you use it as designed and not try to conserve it when its needed.
skater40 is offline
Old 08-21-2009 | 02:48 PM
  #336
Mark dont all pistons orders come with a magnum of Grey G@@se ???LMAO Give Rudy a call you'll be glad u did
Attached Thumbnails BIG Time motor problem ...any ideas  ?????-engine-re-assembly-8-18-09-003.jpg   BIG Time motor problem ...any ideas  ?????-engine-re-assembly-8-18-09-005.jpg   BIG Time motor problem ...any ideas  ?????-engine-re-assembly-8-18-09-006.jpg
BIG Time motor problem ...any ideas  ?????-engine-re-assembly-8-18-09-009.jpg
Old 08-21-2009 | 03:54 PM
  #337
plumbers crack's Avatar
The motors are back together already? glad to see larry stepped up and sent all the parts for you. No charge for the pistons and rings and rods right!
Cool, the power of OSO !
plumbers crack is offline
Old 08-21-2009 | 03:58 PM
  #338
Talking
Just remember 34 degree's on the timing at 5,000 or was that 27 degree's ah shouldnt make a difference its only 7 degree's ! You still running those 85 jets??? on all corners!
Old 08-21-2009 | 05:24 PM
  #339
Timing-whats that?85-what do you mean?
skater40 is offline
Old 08-21-2009 | 07:59 PM
  #340
Holy crap BIG Daddy thats right out of the Larrys Engine & Marine owners manuel
85 jets??? Oh chit i thought u said #65 Jets LMFAO
