Thad Allen's Apache + The Birth of the Cheetah Cat >
Old 08-02-2013 | 05:27 PM
  #651
Comanche3Six's Avatar
Originally Posted by Steve 1
Ed , the game is about "Apparent" surface area and imposing a running attitude , Imagine we cut the boat in 3 or4 pieces and reassemble the thing with the rear sections angled down 2-3 Degrees to the aft , the whole thing is about Friction and trying to lose some as the boat gains speed the running surface goes further to the transom , We have higher pressure in a smaller area of friction is the result , the attitude ? some boats like 3 degrees angle of attack , again up to the cleverness of the designer in shedding the affinity of that glob of water wanting to Cling to the boat hull , Speed , Fuel economy , and longevity of everything in the propulsion system will benefit Greatly .
Thanks Steve
I actually understood a little bit of that! LOL!
Comanche3Six is offline
Old 08-02-2013 | 05:33 PM
  #652
Steve 1's Avatar
Ed , I hope everything is well in your neck of the woods , We have a single engine 30 Vee in the works , I will post more as it nears reality !
Steve 1 is offline
Old 08-02-2013 | 05:58 PM
  #653
Looking forward to seeing it, keep up the great work!
Old 08-04-2013 | 11:33 AM
  #654
Steve,
I don't imagine the 19 your boys are building will look like this one. It was a Morelli and Melvin 19' design we built with core cel and epoxy/glass skins in maybe 1995?? The owner changed boats often, but he told me he will never sell this one. He had another builder 5 years later build a smaller one with verticle tunnel walls and it threw him out of the boat in a turn the first time he tried it.
All the early cats had symetrical hulls, but you see the off shore boats now with asymmetric hulls. How come?
mini max is offline
Old 08-04-2013 | 01:06 PM
  #655
Steve 1's Avatar
Originally Posted by mini max
Steve,
It is easer for us to "dry" the hull up so to speak and make the wetted surface Exactly where we want it ,, The 19 ? built a 15' prototype in 98 or so when I was in the ME , Had to use balsa strips over the Jig which added to the weight , To make a long story short with @65 Hp , 4 big guys in that boat it ran upper 60's and was climbing with a prop that could have been a lot better in Hot Water and Air , Here 75+ No Problem , The Arabs called it the flying Carpet , 7'-6" x 15' .
Steve 1 is offline
Old 12-07-2013 | 09:34 AM
  #656
Steve, are you and your Son building the small cat?
mini max is offline
Old 12-07-2013 | 10:11 AM
  #657
Steve 1's Avatar
Early part of next year , The drawings are being finished now !
Steve 1 is offline
Old 02-04-2019 | 01:57 PM
  #658
Hey Steve it’s JIm
Give me a call in NC 252-402-8810
mini max is offline
Old 02-04-2019 | 02:08 PM
  #659
Indy's Avatar
Member #154
Hey Steve it’s JIm
He's been MIA for years, hope he's ok. You did see the date of his last post right?
Indy is offline
Old 10-13-2019 | 06:36 PM
  #660
Here is my personal Flats Boat 18 Feet all up bagging Dow 470-36 Resin 1'airex core 450# hull and deck, 37 Gallon composite tank in the Bow, the polling platform is also composite as it's legs witch were hi density Foam made in a kind of an oval shape with unidirectional s bagged around them ,I had built a large box spar inside between them to keep everything honest.
The Gelcoat was a white fade to blue on the sides,the boot stripe is a flop of that, white Bottom, Cool boat 50+ with a 70.
The colors remember this was from the Miami Vice days
This Boat was from a panel built Plug.
if I’m not mistaken, I have this boat now. This exact boat. Can you give more details on this hull Steve?
S2kiiNG is offline
