Like Tree0Likes
Bbc # 7 Cyl Loss
Old 04-29-2002, 02:42 PM
turbo2256
Default Bbc # 7 Cyl Loss
How many have lost # 7 cyl as compaired to the other 7 in BBC
Old 04-29-2002, 02:53 PM
My Boats: 1997 23' WPM Cat!!
I haven't lost #7, but it is a common cyl to get pounded especially if special attention isn't given to #5 and #7 plug wire spacing. They fire so closely in the firing order if 5 jumps to 7 it will result in severly overl advanced combustion in #7 and bad things will happen.
WETTE VETTE is offline
Old 04-29-2002, 06:20 PM
Turbojack's Avatar
My Boats: 2003 Eliminator 30' Daytona
Which time? The one that goes most for me is #7, then 5. Except for last year I had # 2 & #6 detonate apart. Wish I knew why? Never had a problem with the even side before in all my years. The problem with #7 is it fires right after #5 in firing order & has not had time to disapate heat so it detonates.
(OK I fixed my post, this is what I get for trying to work while I read/post on OSO)
Turbojack is offline
Old 04-29-2002, 06:38 PM
blue thunder's Avatar
My Boats: 330 Carver 30' Scarab Panther 17' ProV Lund
I think turbo jack means because 7 fires after 5. I wasn't aware of this problem, but it makes sense and I will check it out. I've heard ole number 7 having rod bearing problems due to not warming engine thoroughly before getting on it though.
Anyone know of anything like this that could make #2 have a carbon buildup problem?
BT
blue thunder is offline
Old 04-29-2002, 06:58 PM
Turbojack's Avatar
I do not see why 7 would have rod problems except for being caused by detonation. Of all the pistons I have gone thru over all of the years I have never had a rod/bearing problems.
Old 04-29-2002, 07:31 PM
Crazyhorse's Avatar
My Boats: 38 Cigarette flat-deck
Do you guys bet on #7 when you go to Vega$?
Crazyhorse is offline
cobrapower
New Products and Member Discounts
1
07-22-2012 10:46 PM
eliminatethis
Drives and Lower Units
6
05-20-2008 04:44 PM
TomFTM
Wanted
15
04-25-2008 02:16 PM
razor1115
9
05-02-2007 12:10 PM
