Skater 30 / ILMOR Indy Upgrade >
Old 07-29-2010 | 02:45 PM
  #81
dkwestern's Avatar
What speed does the Stainless 710/#6 32 run?
dkwestern is offline
Old 07-29-2010 | 03:01 PM
  #82
Stainless got snookered when he took delivery of the boat, he didn't get the props that originally came on it so he's been on the limiters at like 118mph w/ the props he has. His GPS unit only reads up to 99mph so he's not really sure unless he's gathered some new data recently.
NASCAT is offline
Old 07-29-2010 | 03:48 PM
  #83
Still, an Email to Shueman about how that eliminator Cspray speaks of would at least get you in the ballpark.
UD
Uncle Dave is offline
Old 07-29-2010 | 03:54 PM
  #84
UD
Probably so that would give me one smaller, lighter boat w/ more power & same drives as well as one larger, heavier boat w/ same power.
NASCAT is offline
Old 07-29-2010 | 04:03 PM
  #85
2 inches of pitch lower would seem like a good place to start.
Im sure Herring,bblades, or throttle up will work with you.
UD
Old 07-29-2010 | 05:13 PM
  #86
UD
2" of pitch lower than what??
NASCAT is offline
Old 07-29-2010 | 05:20 PM
  #87
what speed/rpm /diameter x pitch prop are you running now?
didn't you say you had a bigger set of herrings?
stainless is offline
Old 07-29-2010 | 05:30 PM
  #88
Lower than the eliminators set up spoken of earlier.
I was saying that Shuman will tell you what size and pitch that rig was turning and at what RPM.
I dont know of a closer setup to look at than that one.
The 710 actually makes the same torque as the 725 and it makes it at a lower rpm.
UD
Old 07-29-2010 | 05:38 PM
  #89
My only data is on bravo style props 15.25 33.5 5blade no diffusser Herings
135mph 2 people 1/4-1/2 tank. Didn't think there was any correlation between round ear & cleaver since only the bottom half of the cleaver will be in the water as compared to the bravo prop.
Between yours & the Eliminator I should have a good range for the correct prop to start with.
NASCAT is offline
Old 07-29-2010 | 06:13 PM
  #90
what's your rpm's?
