Cosker On Mystic Delamination >
Old 08-05-2010 | 07:40 AM
  #31
You guys have all missed the point. Just go to the library and check out the book on how to build a 200 mph catamaran. Any of the top builders can build one that won't break. Any of the top builders can build on that will go 200 mph. Building one that goes 200 mph and doesn't break, well, that's another matter. Water pressure formula: Velocity squared X .0147 = pressure in psi. 100 mph x 100 mph x .0147 = 147 psi. 200 mph x 200 mph x .0147 = 588 psi. Get it?
BROWNIE is offline
Old 08-05-2010 | 08:05 AM
  #32
If I understand correctly we just need a customer to order a 50 ( shortened 3 feet to 43 make is fair ) Skater turbine race boat for next year and drop off the check to Peter. To run the Mystic's
Would love to see it
thumper038 is offline
Old 08-05-2010 | 08:09 AM
  #33
BraceYourself's Avatar
I see it as... If JBS was given a race hull (free) then these problems are accepatable. But when JBS spends huge money for the best then the best should be delivered.
Not a ton of money towards someone elses R&D
Otherwise why doesn't JBS own part of the company they are financing R&D for.
BraceYourself is offline
Old 08-05-2010 | 08:32 AM
  #34
BLee's Avatar
Charter Mod
Originally Posted by saxman
Mystic is the only one where ALMOST all of the boats coming out of their door are running 200mph any day of the week.
I understand alot of MTI's and Skater's can push the 170-180 mark on a regular basis, but I would bet there are more Mystics breaking 200 than all other manufacturers combined.
The few Mystics that have been built, were all ordered with 200mph in mind. This could be said about every Skater & MTI built to date, if they were ALL ordered with 200 in mind.
When pushing the limits, you will sometimes find limits, and then you improve.
Nobody has gone where Cosker has gone.
Peter & Randy have gone where Cosker is going many times before, in some cases with more impressive setups that bolting two jet engines to their boats.
BLee is offline
Old 08-05-2010 | 08:40 AM
  #35
Old 08-05-2010 | 08:48 AM
  #36
JBS
Default JBS + Mystic
No matter how much it's explained-Nobody can get my confidence in Mystic or cash sponsors back.
JBS is offline
Old 08-05-2010 | 08:56 AM
  #37
Well thats the harsh truth and we need you to race and sponsors to keep the sport going !!!
Bottom line!!!
Keep up the good work.
Jim
Old 08-05-2010 | 09:03 AM
  #38
AugiePensa's Avatar
Good article. John's a good guy and as you can see a man behind his product. Congrats John.
P4-13 Team THE JERSEY BOYZ OFFSHORE POWERBOAT RACING, OPA/ SBI/APBA/UIM. PRESIDENT: THE JERSEY BOYZ , VICE-PRESIDENT: OPA RACING, THE GREAT SOUTH BAY RACING ASSOCIATION. WAZZUP RACING ENGINES
AugiePensa is offline
Old 08-05-2010 | 09:07 AM
  #39
Wahoo ATV's Avatar
Racer
Originally Posted by audacity
pulled this section off by hand...
Joe,
With that area being one of the most stressed areas on the hull, how will they fix that? As I understand it, any scarfed joint will not be as strong as a single uniform sheet of fabric. Since the single sheet has failed, why would the repair be stronger?
Wahoo ATV is offline
Old 08-05-2010 | 09:16 AM
  #40
Originally Posted by Wahoo ATV
Joe,
Oh ... that ... It'll buff right out.
DLEWIS1340 is offline
