CAT vs V HULL Danger Rating?
#31
[QUOTE=mikesufka;3285326]One quick little story which means nothing, but...
Was running flat out in my Spectre 30/Twin 300 Merc combo a few years ago. 97mph.
The right motor's driveshaft broke.
Nothing happened except the water pressure horn went off and the boat slowed down.
And I spent $$$$ getting it fixed.
I think "cats" are fantastic.
Mike[/QUOT
Mike, your response and the other responses I have read on this forum are getting better and better! I was getting worried....!
Mike[/QUOT
#32
"How you setup your cat before you go into a turn makes a big difference, not just speed". Please elaborate! If I sit here and think about this statement, my first reaction is that in my very limited experience the cat I have really resists turning unless I am up to plane speed which I think is about 30 or 35 mph. Maybe a little more at Tahoe. This is why I need a lot of seat time to see just how this thing turns and behaves under lots of various conditions. I watched the right sponson dip downward when turning left and vice versa. Guess I need to find out how much this happens at slow speeds at more and more truning angles. This will happen as soon as the weather gets warmer, but I am hopefull some of you good folks here on the OSO forum and help me with your insights.
Rick
Rick
#33
I respectfully disagree
The operational skill to operate a cat in the rough is far greater
then a vee. Cats will actually fly across the waves. This is where there will be a narrower margin in operating it safely. A vee will plow through the rough at a lower speed lending itself to a bigger margin for safety.
Take two top throttle men put one in a 47 vee
the other in a 46 Cat and run them side by side the cat
will be faster.
will be faster.
#34
This was a direct quote from an insurance agent and almost an exact quote from a boat dealer who told me he could sell me a cat or a V but he highly recommended that I don't buy the performance Cat.....
#36
I have owned ten cats over the years. I have blown engines, drives, transmission and even lost props. In every instance the boat simply slowed down. The worst was a blown number six at 150 mph, again slowed down. Made one heck of a noise and grinding. A skilled cat driver can run faster in rough water than a v hull. Many cats will lean into the turns slightly such as Skater and MTI.
Rick
#37
Even on my one outing, I had it up to about 70-80 in at least 3 ft chop, maybe a little more - middle of Lake Tahoe - extremely smooth ride with the feeling of a little bab, bab, bab of the wave tops from my seat and through my feet, and twice I could tell the boat came out of the water. No drama, NOTHING. Completely level and stable. Just the realization that I made a little jump.
Rick
#38
Just how did you manage to do this??? I really want to know so I can hopefully learn from your mistake. Something like this can hurt people or worse.
#39
I have no cat experience so I can't help you,and while there are many knowledgeable people on this board you are not going to learn the theroy of how your hull operates here.You really need to talk to a guy like Tres or some one who can teach you.You need to understand why the boat does this "not do this when it does this."
Rick
#40
