Bleeding power steering
Old 05-28-2002 | 01:08 PM
blackhawk
Default Bleeding power steering
Last fall I removed the motor and gimbal assy from my boat. I have put everything back together. I lost some power steering fluid in the process. I filled the resevoir and it seemed sucked quite a bit of that down which I immediately re-filled again. The problem is I still don't have any steering. It seems like it has air somewhere in the system. It is not external steering. It is the stock system, I believe it is Hynautic. I think that the cylinder itself needs to be bleed. Can anyone help?
Old 05-28-2002 | 02:05 PM
skatermike24's Avatar
Hynautic I think has a web site they should be able to fax you the bleedings process.
call the 1-800 http://www.marinecontrolsys.com/
skatermike24 is offline
Old 05-28-2002 | 02:40 PM
MitchStellin's Avatar
You should not need to bleed this system. You can crank the wheel back and forth and feel a jerky motion. Keep going back and forth until the jerking stops. This should do it. Check the level afterwords.
MitchStellin is offline
Old 05-28-2002 | 02:42 PM
obnoxus's Avatar
Charter Member #1171
Yep,,, Simple,,, DONZI Mitch has it !!
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 05-28-2002 | 03:25 PM
The steering I had on my boat had to be blead back at the ram. good luck!
Old 05-28-2002 | 05:04 PM
blackhawk
Mine does nothing. Turn the wheel either way and the ram just sits there. So I am thinking that the ram needs bleeding. There is a large bolt on top that serves no apperant purpose, so I am assuming that it is a bleeder of some sort. I left a message with marine control, hopefully they can fax a "procedure".
khanson1982
7
09-07-2008 11:52 PM
GoFastSonic
2
05-05-2008 07:17 AM
Yellow_ICC_OK
13
05-01-2008 12:08 PM
jrocket
5
04-01-2003 08:10 PM
fishead
3
05-22-2002 11:33 PM
