I give up
Old 06-03-2002 | 04:33 PM
Jayl13's Avatar
Mark, let me know what day is best for you
I can leave work early by a hour or two no problem
I have a wizzer wheel at home too (has the shield on it, have to take that off im sure)
Let me know what day is good for you and ill make sure im there and get you directions
Jason
Jayl13 is offline
Old 06-03-2002 | 04:37 PM
cougarman's Avatar
Default Not Stainless
Jay,
Those bolt's are not stainless. They are just rusty
pieces of crap.
Cougarman
cougarman is offline
Old 06-03-2002 | 04:47 PM
HiPerf2000's Avatar
Whenever you want dude!!! I can get there tonight if you want....I get out of work in 10min....can run home get my stuff and be at your joint by 6:30. Gives us 1 1/2 of daylight to wack two bolts.
If you don't want to do it tonight....I have the same schedule tommorow.
let me know.
HiPerf2000 is offline
Old 06-03-2002 | 04:48 PM
puder's Avatar
speel chekk this fokker!
i had teh same problem with my old exhuast manifolds. Go to home depot buy a dremel and some high speed cutoff discs. Not teh stone ones but the reinforced flexible ones. Cut the heads off the exhaust bolts. Its a pain in eth ass but it will work. ANd it will be much easier to get eth bolts shafts out once you can cranka vise grips on them and you have some space to work with instead of trying to get a socket on a trashed bolt in a recessed manifold hole.
Pardon me, while I whip this out!
puder is offline
Old 06-03-2002 | 04:51 PM
Jay-I feel your pain! I think I am on the down hill again the new 502 from runs new got here to day so with cam change and the bolting on all the goodies she is set to go again soon!When things would go from bad to worse for me I would just rember that I am strong as bull and smart as tractor
FloridianSon is offline
Old 06-03-2002 | 05:03 PM
NASTY HABIT's Avatar
Hell.......... i'm ready to fly up myself and give a hand..... I feel your pain....This kinda stuff happens to me all the time...usually when the tools stop flying i feel much better...then i pick them up and dig back in... I just used the same cutoff saw on 2 ,1/2 inch stainless bolts on my engine hatch cylinder mount...it'll work...good luck ... and as already said when you are done knowone will know that engine compartment better than you...
NASTY HABIT is offline
Old 06-03-2002 | 05:12 PM
Like everybody else said RELAX!!! walk away from it for a while take time to think about what your doing then go back to it. Like Cougarman said use a torch. hell!! if youre not worried about what happens to the engines you can cut the dam things apart peice by peice just be extremely carefull were the sparks and slag are falling.
THRILLSEEKER is offline
birdog's Avatar
B-fore you go cutting...............Go to ashop that works on BIG trucks....They will have a 3/4 drive impact gun and a serious source of air. There is a HUGE diff between that setup and a small homeowner setup !!!!! {trust me} somrthing like 8-9 hundred pounds & lots of air to run it!!!!!!!!!!!
Take a deep breathe
birdog is offline
Old 06-03-2002 | 05:41 PM
Ike's Avatar
Ike
Charter Member#93
Jason,I'll not far from you, bring your boat to my shop in paoli and I'll get them out for you. Call me at 610-647-8640 Ike
ps. I did not think what chris said was nice but after seeing his avator I'll let him slide
Ike is offline
Old 06-03-2002 | 05:57 PM
Playn's Avatar
Jay,
Keep your chin up bud. It didn't take too long before a OSO member in your area read the post and offered to lend a hand (that's what this board's about)
I agree with stepping back for a day or two, relax, and then tackle the problem. Don't bail now!
Keith
Playn is offline
