Mobil 1 Walmart Issue. L.I.'s Help
#32
You guys might want to be careful just buying your synthetic oil just based on price alone and just using standard current Mobile one synthetic. The standard Mobil 1 synthetic is a automotive emissions based oil and does not have any good zinc based anti-wear packages blended in the oil for the heavy duty use the standard marine performance engines need. As for Mobil 1 a good choice would be the Mobil 1 V-twin 20-50W which has a much better wear package in the blend. there are also other good synthetics out there such as Amsoil, etc., that have good blends for marine performance use so try not to be to "penny wise and dollar foolish" in your oil purchasing and use. Just a suggestion.
Best Regards,
Ray @ Raylar
Best Regards,
Ray @ Raylar
#33
The Mobile 1 V-twin oil is actually motor cycle oil for Harleys and is a 20-50w which I prefer for high performance marine engines. It is not sold in 5 qt. jugs as Harleys don't use that much oil at an oil change so I believe its only available in qt. bottles. If you look at those Mobile 1 charts you will see it has the highest zinc and phosphorus levels of any 15-50w or 20-50w synthetic oils Mobile 1 makes other than a straight weight racing oil. If its my engine I am going to use the 20-50w V-twin and not worry about a few bucks more per oil change waiting to find the product at WalMart. Some boaters here on OSO were buying straight Mobile 1 10-40wand not the extended duty 15-50w Mobile 1 that Mobile has discontinued for now.
Best Regards,
Ray @ Raylar
Best Regards,
Ray @ Raylar
#34
http://www.amsoil.com/storefront/rd50.aspx
http://www.amsoil.com/storefront/ame.aspx
Second oil has high TBN for soot An corrosion control.
I have used the second one for 15 years 1000 hrs without any tear down and refresh. This is the ultimate test.
#35
Best Regards,
Ray @ Raylar
Best Regards,
Ray @ Raylar
#36
HERE IS THE ANSWER DIRECTLY FROM MOBIL:
Question:
Will Walmart Carry Mobil 1 15W-50 in 5-Quart Jugs?
Hi. I need to know if the 5-quart jug of Mobil 1 15w-50 is going to be available at Walmart. I've been checking for the last two months and have had no luck. Is the 15w-50 5-quart jug discontinued?
Answer:
While Mobil 1 15W-50 in five-quart bottles isn't currently available at Walmart stores, due to popular request, the product will return to Walmart locations this summer. Expect to begin seeing the bottles at select locations from July through August, with a full nationwide distribution in March 2012.
Question:
Answer:
#37
Alright....I'm going crazy with this. I just picked up a 98 Formula 312 with 454 MAG MPI's in it. I use to run 20w50 Valvoline racing oil in my old boat but someone told me not to run that oil in my Formula. They said to use the 25w40 Mercury high performance oil.
The previous owner was no help to me as he took it to his marina and let them take care of everything.
Any help would be appreciated!
Dave
Dave
#38
So being forced to purchase qts, we have a few offers in our area from auto parts stores for 5qts and they throw in a Mobil 1 filter for $37.99. Does anyone know what Mobil 1 oil filter would be for a 2000 HP500? Are they as good as using the Mercury part?
