GPS data behind the "My Way" shootout runs. >
Old 09-02-2011 | 10:24 AM
Airpacker's Avatar
Originally Posted by Steve 1
The boats are built from material that is invisible to radar,so using that system is a bit of a joke you can never expect a good reading,Laser beams would be one option.
yep, LIDAR would work
Airpacker is offline
Old 09-02-2011 | 10:27 AM
Is that anything like "LIE-DAR"?
That's what most guys I know use to measure their speed.
cubicinches is offline
Old 09-02-2011 | 10:37 AM
1) I would sure as hell hope that YOU are the only thing on the course when YOU are running over 200mph.
2) set the lights too high for the fish. It works in drag boat racing and has for decades.
3) Computer timing systems post speed and ET in milliseconds. I think the spectators could wait that long.
4) Not too likely there would be calculation errors.
Drag boat racing is done in creeks were the water is not a 3/4 mile wide. Drag boat racing also uses poles driven into the ground for the beams to set on. If I am not mistaken this particular area is about 64' deep making that a little impractical.
Lets face it, this is an event for charity. It does nat make any difference wether MYWAY speed was 208 or 217, it was clearly the fast boat there and he was awarded the same as he would have been if they had recorded 217. If the top speed is important to the owner go out and show us on GPS.
Allen
29scarab10 is offline
Old 09-02-2011 | 10:41 AM
MYWAY was aware of this problem when the boat was in the dock before they drivers meeting Saturday morning. On the front port side sponson he had a device bolted thru one of the hatches in which I assumed was for the rader to pick up.Maybe this device was to small and is why the rader gun did not pick up 2 of his runs. Other dealt with the problem in other ways for example Eddie Young and Bruce Gibson covered the noise of there boat in a metal tape.
Allen
Old 09-02-2011 | 10:42 AM
Steve 1's Avatar
Allen
Does not matter cops do not have poles "driven into the ground" and measure your speed just fine.
Steve 1 is offline
Old 09-02-2011 | 10:43 AM
FunHome's Avatar
It seems a Laser Speed Detector Mfg. would see this as a opportunity to showcase their equipment...
FunHome is offline
Old 09-02-2011 | 10:53 AM
In my area cops do not use beams for timing equipment. They use rader or laser.
Old 09-02-2011 | 10:56 AM
You ever notice cops using lasers hold it real close to there eyes. They are doing this aiming this device. They way it was done at the shoouout no one was on the boom lift. the rader guns are fixed mounted and have a display remotely mounted making sure that human error was not in the equation.
Old 09-02-2011 | 11:03 AM
Just had the argument about radar accuracy with my best friend (local cop). They just had the latest Stalker system installed in one of their squads. His only comment was that the new stalker system that is permanently mounted in the squad car is much more accurate then models before. It interfaces with the vehicles powertrain control module to pick up vehicle speed. So my argument to him was that if they are running either low or worn tires wouldn't that affect the accuracy.... I think so! Let's face it, lights are way faster than sound (radar.)
TylerBurich is offline
They could use a vbox ( http://www.vboxusa.com/products.php ) with the optional remote hard mounted signal base to boost accuracy. Also, could use telemetry so judges could see data realtime and download remotely.
I've used them and they are pretty darn accurate.
ECeptor is offline
