Cockpit construction
Old 11-29-2011 | 01:06 PM
  #191
I've seen that to. Apparently it's used to measure g-forces on packages sent trough the mail or something? I've never seen it being used in other safety applications. I'll google it and see what I can find.
Accelerometers used for hi G's cost a few $$$. Good ones cost about 2500$ and OK ones around 100$ each. There are also cheaper ones but I'm not sure what acceleration levels they can withstand. You will also need some kind of recording system.
What type of measurements would you like to do?
Edit: Found it! http://www.shockwatch.com/
Gripenland is offline
Old 11-29-2011 | 01:21 PM
  #192
glassdave's Avatar
Neno the mind boggler
Not sure just thinking out loud here to see what comes up, trying to apply whats out there. I was wondering if they had any of those patch like things that could do PSI.
08 OPA High Points Champion
glassdave is offline
Old 11-29-2011 | 01:30 PM
  #193
There is pressure sensitive paint. But I've only seen it being used for air pressure.
http://psp-tsp.com/
Old 11-29-2011 | 01:33 PM
  #194
Who is responsible for the design of the canopy on Citron, Talkin Trash, and Miss G? Mystic?
40FlatDeck is offline
Old 11-29-2011 | 02:03 PM
  #195
Glassdave, if you want to measure loads on a cockpit i would recommend strain gauges. They only cost a few $ each so you can apply them in a pattern over a large surface.
The strain can be translated in to stress which will help you analyse your design.
Old 11-29-2011 | 02:46 PM
  #196
Originally Posted by shifter
Piston powered pleasure boats are running 198. Making the raceboats slow down will not make the industry evolve.
pat W
i know we're straying off topic here, but my point was that canopy safety and designs aren't strong enough for supercat speeds(120-130ish). or atleast some the current boats are behind and the some of the best might not be enough. if steve1's math is correct the unlimited class boats would need to be built to twice the design strenght as some of the current ones.
so while slowing down the unlimited boats or overall top speed of raceboats in general will not let technology "evolve". its quite apparent that the technology of SAFEY hasn't kept up with the speed.
as for the pod design: would it be feasible to do model testing in a wave tank ?
skaterdave is offline
Old 11-29-2011 | 02:49 PM
  #197
Steve 1's Avatar
Maybe a Chopper drop test into seawater.
Steve 1 is offline
Old 11-29-2011 | 03:08 PM
  #198
at what elevation would the chopper have to be at to duplicate a 150 mph crash ?
Old 11-29-2011 | 03:23 PM
  #199
Steve 1's Avatar
Having to go back and forth ,Quick guessamation, meters to feet @ 7.7 seconds and 300 Meters ,now the shape has to be factered.
Steve 1 is offline
Old 11-29-2011 | 03:33 PM
  #200
Steve 1's Avatar
The Glass Dave Egg shaped Pod and a Thicker single Canopy UNCUT!
Steve 1 is offline
