Help Help Wellcraft Nova 26st made sudden turn at 63MPH >
Old 03-07-2012 | 10:34 PM
Randy Nielsen's Avatar
Thank you frankenstein I did a twin outboard install on a south american banana boat a few years ago set it up counter rotation, ran fine the customer changed it to same rotation & about killed himself when he cracked the throttles wot thats why I asked that question.
Randy Nielsen is offline
Old 03-07-2012 | 10:35 PM
Alot of good responses, but in my opinion, none of them answer the problem. I don't have an answer, but if your boat makes an extreme turn all by itself, and does this more than once, it isn't a " lack of experience in a go fast boat" issue. Their is a mechanical issue. I wish I could help more, but I don't turn the wrenches, I just run the crap out of her.
frankenstein is offline
Old 03-07-2012 | 10:42 PM
When the boat comes up on plane trim the drives up a little at a time you will feel the difference & the rpms will come up the boat will feel a little looser but easier to control if you trim too high you will vent the props youll knoww when that happens trim down a little from there & you should be fine
Old 03-07-2012 | 10:48 PM
How much play is in the steering (how far can you move the drives side to side setting on the trailer?)
Old 03-07-2012 | 10:49 PM
hullofjustis's Avatar
you may have a very bad hook in the hull. take a 6 foot straight edge from transom fwd on the bottom of the hull, check strakes and all surfaces you should not see light where straight edge meets the bottom. if there is very little gap I wouldn't worry. but it is very possible with four blade props and a low x dimension may be causing a lot of stern lift at higher speeds.
hullofjustis is offline
good advice randy,i think he is experiancing bow steer,trim the drives up/out,and it should go away.
mike tkach is offline
Old 03-07-2012 | 10:58 PM
Thanks Mike could the prop rotation cause issues with handling like that also?
Old 03-07-2012 | 11:01 PM
Guys thank you all for your time and i will try some of your advises,will post results soon,
By the way props are bravo 1 26p 4 blade.
Diego9040 is offline
Old 03-07-2012 | 11:07 PM
I hope everything works out for you, there is nothing worse than having an expensive toy you cant play with, good luck & let us know how things work out. Randy
Old 03-07-2012 | 11:11 PM
You guys are great,thank you.
