Offshore Performance Boat Under 26' With Windshield - Does This Exist? >
Old 04-08-2012 | 01:23 AM
  #31
Originally Posted by VtSteve
Once you put the term Performance in front of the category boats, you have to have both a larger budget, and an ability to tolerate compromise. Especially true of anything smaller than 30'.
That Velocity 260 looks to have a relatively large cabin, plenty of seats in the cockpit, but not much cockpit room. For a smaller boat running in the ocean, I'd be looking at heavier with a deeeeeep veeeeee. I'd rather give up some speed and not be pounding.
28' seems to be the normal size every boat maker has switched to, and even then, you have to look to actual hull in the water, not swim platforms and sharp bows. Probably a boat 65 mph or under with a good deep vee would be your better starting point. Then weigh the performance aspect. But those are my guidelines, and everyone has their wants. My first choice would be to look at Formula 270 Sunsport. Not the fastest, but it's a 7,000 pound boat with a 22 degree deadrise.
My favorite all around in that size would be an AT, but no windshield. I'll bet one could be made though.
Steve, I totally understand what you mean about weight and pounding, and appreciate the input. Unfortunately, I don't have the space, the tow vehicle, or the gas budget for the larger boats. I either have to compromise, and restrict myself to calmer conditions, or be boatless and stay on shore.
Michael
Michael1 is offline
Old 04-08-2012 | 01:25 AM
  #32
Originally Posted by 97FASTech
Must check this out, top of your list:
http://www.offshoreonly.com/forums/v...ed-advice.html
If that boat is in good condition, it seems like a good buy could be had there. Unfortunately, it is the model with the lower wind deflector, rather than a windshield.
Michael
Michael1 is offline
Old 04-08-2012 | 07:12 AM
  #33
Michael
It's hard for sure. Good ride, some comfort in bigger water, smaller boat, single engine. Tons of people want that for all of the same reasons you do.
I've never been in a Sutphen or Velocity, so others will have to speak to that.
Compromise is what boating is all about, since you'll never find the perfect boat. Some do some things well, not others. I like the AT layout, since a bigger cabin with enclosed head is in my top three. Very tough to find in a boat this size. Perhaps a used boat is in the cards for you.
You'll have to determine your own top three Must Haves within your size and weight limit. Myself, I'd go for the better ride, nicer cabin, and cockpit layout. Speed would be in the bottom. I'd rather have a boat that could go 50-60 in bigger water, than a 80 mph boat that would pound the crap out of you and could only do 30 in those conditions.
Be a good time to get some rides in various boats and see what works.
VtSteve is offline
Old 04-08-2012 | 07:59 AM
  #34
You might want to check out checkmates zt line of boats . They make them as small as 23 ft with or without windsheilds. All 24 degree deadrises.
invader is offline
Old 04-08-2012 | 08:19 AM
  #35
JWoolever's Avatar
I think you can get a new Baja they are now a 245 or 278
http://www.bajamarine.com/performance/main.htm
JWoolever is offline
Old 04-08-2012 | 08:57 AM
  #36
I would look at the Formula 271 model, can handle the toughest waters and has plenty of room, they are heavy so not a speed demon low 60's is usually where there at, also the older version the 242 is a awesome boat and plenty of reputation to go with it, also I would definitely consider the Velocity, 260/280 the 260 is actually a 24 and the 280 is really a 26, these boats are definitely deep inside however most only have a windscreen
good luck
88242LS is offline
Old 04-08-2012 | 11:20 AM
  #37
The Formulas are very nice, nice layouts and finish, and pretty good heft to them.
I just looked at the Checkmate ZT260. It says dry weight is 4,000 pounds? With the engine? Sounds pretty light for a 24 degree 26 footer. How do the Checkmates take the rough water?
VtSteve is offline
Old 04-08-2012 | 11:27 AM
  #38
Not sure about the newer Cmate's but my buddy has a 96 253 and its fast but most of the time its a fish outta water
88242LS is offline
Old 04-09-2012 | 11:17 PM
  #39
Definitely, would want the boat that would have the advantage in bigger water. I hate getting pounded. I'm not too concerned about the cabin, since I don't think I would stay overnight in it without an enclosed head. I just can't picture myself sitting on the can in front of my significant other (if and when there was one in my life).
Steve, good advice. Thanks.
Michael
Michael1 is offline
Old 04-09-2012 | 11:35 PM
  #40
Originally Posted by 30ctsutphen
http://www.powerboatlistings.com/view/11640
Thats my boat. Hated the windsheild when I bought it but after using it I really like it fubctionally now. No wind noise even standing and tge side vent windows work like A/C when open
Could do up a 26 sutphen the same way and they are great in rough water. Theres one for sale for 17k here in CT too
After years of construction equip and drag racing I appreciate the quiet of the Outboards and the windshield
Best of luck on finding whats right for you. Forget the go fast image and go for the right fit!
I looked at the 26 Sutphen you mentioned, but it only had a wind deflector, no windshield.
I'm not worried about image. I learned long ago that's how to end up with something others like, but not the person buying it. It's strange that all the big, high end boats like Outlimits' or MTI's have windshields, but not the smaller, less expensive performance boats. I must have expensive taste. BTW, I noticed Outlimits is coming out with a 28...with a windshield.
Michael
Michael1 is offline
