Popping threw carb
Old 04-18-2012 | 06:37 AM
Originally Posted by TxHawk
Exactly!
So my recomendation for your issue is this:
It sounds like a lean pop. Those are no big deal, lean is mean. The harder you run it, the more it will just begin to sort things out itself.
x 8 trillion.
Lean is best, that way you get great power on little gas.
looseconnection is offline
Old 04-18-2012 | 12:42 PM
Exactly!
Sort itself out = like out the pan
Wholly ccrraappp
thumper038 is offline
Old 04-18-2012 | 12:47 PM
Usually when I get that lean pop, I immediately stab the throttle to the dash a hold it. This way whatever is in there cleans itself out.
Since this is a blower application, be sure to run 3/16" fuel line from tank to carbs!!
MILD THUNDER is offline
Old 04-18-2012 | 01:48 PM
You guys are FUNNY!!
CrownHawg is offline
Old 04-18-2012 | 01:50 PM
lean pop usually means $$$$$$$$$$$ Mine did that and all it ended being was rust on the pick ups in the msd distributors. Cleaned them up and everything was ok. Lean pop on dialing in a engine is not a good sign. Mine was locked out a 30 degrees as well. Good luck!
BOATMAN302 is offline
Old 04-18-2012 | 02:05 PM
Nice Pair's Avatar
Originally Posted by hujh2012
I was running last weekedn just put my 572 10-71 motor with a chiller in and ran it. The engine blew back threw the carb about 3 time. Once was just going along it blew back. Anoter time was just tryin to get on plane then after getting on plane. I set the timming at 30 degrees and locked it. It pinged as i just started to make boost so i backed the timing off. The valves are set at .018 thousanths on the intake and exhaust any help much appriciated.
Replica Dolce & Gabbana Shoes
Retail Air Force One Shoes
"Nice Shoes"
Nice Pair is offline
